August 22, 2025, 12:30:59 AM *
Author Topic: Rear Brake Caliper  (Read 1065 times)
indybobm
Franklin, Indiana VRCC # 5258
« on: November 01, 2011, 12:57:00 PM »
I bought a used rear brake caliper from Pinwall. I wanted to rebuild it and put it on my bike this winter, then rebuild the one I take off as a spare. It is off of a 98 Tourer, same as mine. I cannot get the pistons out. They do not move or spin at all. I have tried air pressure (90psi) with no success.  I am not through riding for the year or I would hook it up to my rear master cylinder and us that to move them. Should I get another caliper and give up on this one?
So many roads, so little time
VRCC # 5258
Tom McInerney
« Reply #1 on: November 01, 2011, 01:29:13 PM »
I would think you could fill it with brake fluid ,hook up the brake line and push them out with hydraulic pressure.
« Reply #2 on: November 01, 2011, 01:38:05 PM »
you might try letting liquid wrench have a go at the pistons, and then try again. Before
I had a decent compressor I used to take my calipers up to the man at the NAPA store,
and blow the pistons out with his giant compressor... I like the hydraulic pressure idea,
but I've never tried it, and can imagine me making a giant (paint eating) mess with it  Wink
Good luck...
« Reply #3 on: November 01, 2011, 01:46:13 PM »
If you have a grease gun you can hook up the grease gun and push them out.
Just another hydraulic press.
Fill the caliper with oil to save the grease.
You can get a connector for the two at the hardware store.
« Reply #4 on: November 01, 2011, 05:10:24 PM »
If this works (sounds like it would), and it's that easy to make the
connection, this belongs in that "tricks of the trade" thread someone started...
eric in md
« Reply #5 on: November 01, 2011, 05:44:02 PM »
 cooldude  yep works good too.fill some with oil and then pump it with a grease gun until pistons push out..
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #6 on: November 02, 2011, 09:34:15 AM »
Yes, be carefol with air to prevent the piston from coming out like a bullet when it lets loose, grease or oil is much safer.
