August 22, 2025, 12:30:53 AM *
Author Topic: going darkside  (Read 1185 times)
carl1up
sardinia ohio
« on: November 06, 2011, 02:08:24 AM »
just ordered my altimax today, need to know what all i need to get in the way of parts materials etc. oil grease o-rings ?????  thanks-------carl
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #1 on: November 06, 2011, 05:37:22 AM »
Carolina Bike and Trike is where to get the O-rings.
Check out this thread.
http://www.valkyrieforum.com/bbs/index.php/topic,29622.0.html
Order here:   http://www.carolinabikeandtrike.com/ORings.htm
« Last Edit: November 06, 2011, 05:42:39 AM by Fudd » Logged
Save a horse, ride a Valkyrie
« Reply #2 on: November 06, 2011, 11:11:33 AM »
While apart, think about what else you need to do.
Pull the drive saft, lube the WHOLE rear end. You'll also need to keep in mind that this is a 10K maintenance while you have the CT on.
Also read up and decide if you want to do the bearing mod. Changing out the single roller bearing on the LH side, to the same double roller on the RH side. Do a search and read what people say.
« Reply #3 on: November 06, 2011, 12:11:19 PM »
Have a look at everything back there. Good time to look at rear brake pads and condition of brake fluid. Should be clear or light straw color. If it looks like tea or coffee-change it out(DOT4) with new. Take a moment and install metal air valves also. Going D/S-welcome for you are now forever lost. 2funny RIDE SAFE.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #4 on: November 06, 2011, 05:18:02 PM »
The WHOLE rear end includes pulling the drive shaft out of the pinion cup and cleaning both.  There are two holes at the bottom of the pinion cup that are half hidden by the flange nut that holds the cup on.  Use a pick to thoroughly clean these as well.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
carl1up
sardinia ohio
« Reply #5 on: November 07, 2011, 01:12:51 PM »
thanks guys been very helpful ordered o-rings,looking for bearings hoping to ride this weekend.  thanks again------------carl
