February 03, 2026, 06:45:32 PM *
Author Topic: Stebel Horn Mounting  (Read 1935 times)
Hedgehog
« on: November 13, 2011, 06:57:33 AM »
Dave King
Proud owner of Honda Valkyrie F6C 1997 Standard
& owner of BigBikeMad.com
Chiefy
Sarasota, Florida
« Reply #1 on: November 13, 2011, 07:54:34 AM »
Hedgehog
« Reply #2 on: November 13, 2011, 10:04:10 AM »
Nice bike you got there chiefy - what exhausts are those?
Hh
Dave King
Chiefy
Sarasota, Florida
« Reply #3 on: November 13, 2011, 10:13:40 AM »
Hh
Two brothers racing.  6 into 2 slip-on.  Sounds pretty good, and not loud enough to give me a head-ache.
Toolman Tom
« Reply #4 on: November 16, 2011, 08:50:55 PM »
Hi Hedgehog -
Love the horn mounting.  I want to do the same.  Did you make a bracket to mount between the horn and bike?  If so, can you show the design and dims.
TKS...Tom in Atlanta
Hedgehog
« Reply #5 on: November 17, 2011, 07:44:15 AM »
Thanks Chiefy, that's helpful  cooldude- I'm looking for a replacement for the OE ones that someone has cut about - they are now too loud for long rides. Would you say the 2 brothers stuff is quiet enough to tour with?
Mind me asking how much you paid? Embarrassed
Thanks.
HH
Dave King
Hedgehog
« Reply #6 on: November 17, 2011, 07:52:47 AM »
Hi Tom,
I got one of those steel horn mounting strips that you get with some cheaper horns (about 70mm long and 20mm wide with a hole drilled at each end). I folded that in half (so then only one hole at one end, drilled another hole at the other end in the now thicker and shorter strip of metal, and then bent it in a dog leg (bend to the left, right and left again).
That then goes on a bolt from the petcock mounting. I used rubber washers so the bolt had to be longer than the one it replaced. Smiley
Its shown a bit wonky in the picture, but its easy to adjust and now sits at a perfect 90 degrees.
I put a rubber bush on the bottom end that sits on the engine casing, taking some weight and reducing vibration.
So far so good... Grin
Dave.
Tomorrow its three gauges from motosens to fit (radiator temp, volts and clock) plus a blinker buddy...
Got a Gear change indicator coming from Holland next week!! Roll Eyes
Ride safe.
HH
Dave King
Chiefy
Sarasota, Florida
« Reply #7 on: November 17, 2011, 05:33:17 PM »
Thanks.
HH
Everything is relative.  I wear a full face helmet, and the noise doesn't bother me.  Although on a tour I might throw in ear-plugs.
They don't make these mufflers any more, and they were on the bike when I got it, so don't know what a used set costs.
BIG--T
The Twilight Zone
« Reply #8 on: November 17, 2011, 07:20:37 PM »
That looks great and helps fill that hole. What kind of Stebel is it. I've looked at several but is hard to find chrome. where did you get yours and what are the dbs?
Chiefy
Sarasota, Florida
« Reply #9 on: November 17, 2011, 07:34:52 PM »
From a quick google search.  You should be able to find it cheaper.  I got mine at my Honda shop.  Amazon was cheaper then the Honda shop.
http://www.amazon.com/Stebel-Nautilus-Chrome-Compact-Motorcycle/dp/B003SEBYF0/ref=sr_1_3?ie=UTF8&qid=1321587203&sr=8-3
BIG--T
The Twilight Zone
« Reply #10 on: November 17, 2011, 08:08:09 PM »
Thanks, I liked the reviews and the price is right1
Hedgehog
« Reply #11 on: November 18, 2011, 12:34:18 AM »
Yeah,
I got mine from Amazon too.
Last one I could find in the UK, everywhere here seems to be out.
Dave King
BIG--T
The Twilight Zone
« Reply #12 on: November 18, 2011, 07:19:52 AM »
Did ya'll get the plug and play?
