February 03, 2026, 06:45:32 PM *
Author Topic: should I pull the u joint  (Read 1476 times)
justooneez
« on: November 14, 2011, 02:26:23 AM »
Hi, getting closer to getting the bike back on the road, got the back end apart, but it looks like to get to the u joint I gotta pull the swingarm completely off.
I guess what my question is, is there a better way, and should I do it, bike only has 13000 miles on it, but its been sitting in my dads garage for an unknown length of time (probably 4-5 years), I know that on the site it says to grease both sides of the ujoint, so I was hoping for advice on getting it done, whether it needs it or not, and how often it should be done Smiley
On a positive side, the splines looked lubed, and so did the pinion cup, and the end of the shaft that went into the u joint had lube too.  No wear detected by my untrained eyes anyways  uglystupid2
Thunderbolt
Worthington Springs FL.
« Reply #1 on: November 14, 2011, 02:46:48 AM »
http://www.rattlebars.com/mtz/ujoint.html
Joe Hummer
Arnold, MO
« Reply #2 on: November 14, 2011, 04:59:13 AM »
Let me get this right...you are working on the bike after it has sat for 4-5 years so you can get it back on the road and have some piece of mind that it won't let you down while you are out and about and you are questioning whether to check the u-joint?  Really?   Evil
Just messing with you....somewhat...seriously though, I would jsut so I knew it was good.  It probably is just fine with those miles on it but it is really pretty easy to get to so you can check it.  Follow the instructions given above and you will be good.  Most people have problems getting the boot back on the first few times they do it.  I have started twisting mine back on and it works out pretty good.  Start by lubing the edge of the boot (big end) with a little WD-40.  Slip as much as you can of the boot on the lip, and twist it until it is fully seated.  Twist in the same direction, not back and forth.  The motor side can be pushed on without too much trouble.
Joe
1999 Valkyrie Interstate
justooneez
« Reply #3 on: November 14, 2011, 07:40:55 AM »
Sweet, exactly what I was looking for, a way to pull it without dropping the swingarm Smiley  not that I'm lazy mind you, well somewhat, just I'm nearing the end of my meager budget and my mechanical skills are somewhat challenged  uglystupid2
Thanks again
Cruzen
Wigwam Holbrook, AZ 2008
Scottsdale, Arizona
« Reply #4 on: November 14, 2011, 08:36:03 AM »
I replaced the universal without removing the swing arm earlier this year but be advised that if you have hands the size of feet you may not be able to get your fingers in there.  The hands in the tutorial are small in size. Thanks to recommendations from Sandy, I used a bit of white grease on the rubber boot to ease getting it back on.  You will also have to move the swing arm up or down to get the drive shaft aligned when you put it in.  In my case I had to move the swing arm up a bit when installing the drive shaft.
The trip is short,
enjoy the ride,
Denny
