February 03, 2026, 06:45:28 PM *
Author Topic: Wind is beating the crap outa me.  (Read 2784 times)
« on: November 15, 2011, 04:31:02 PM »
Comes in under the fairing and over the tank. Does anyone have fork mounted deflectors that don't interfere with their radiator pods? I have access to some Memphis Shades fork mounts that I  plan to use, but so far haven't come up with a wind deflector design that  doesn't hit the pods.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: November 15, 2011, 04:34:17 PM »
Need more storage to go with the reduced wind?
http://www.aerostich.com/aerostich-tank-panniers.html
RTaz
Oscoda, Michigan
« Reply #2 on: November 15, 2011, 04:44:17 PM »
I have the fork mounted wind defectors on mine and it seems to work well. I also have a knock off  wind defector mounted and I get no wind coming over tank.
 RTaz
« Reply #3 on: November 15, 2011, 05:25:43 PM »
I can't tell exactly what you're using, do you have a head-on shot or two? I see you have Baker Air Wings, are they for the I/S or ??  I have a set of them mounted but if I added the deflectors under the outer part of the fairing like your picture shows, they would hit the Bakers. I've been debating about removing the inner triangle section of the Bakers and adding the fairing piece. I need to see your's from the front, what brand are your fork deflectors...or are they homemade?
Thanks.
NITRO
Eau Claire, WI
« Reply #4 on: November 15, 2011, 05:48:34 PM »
I use Big Bike Parts/Showchrome fork deflectors and Baker Air Wings on my IS and I do not have any of the problems you mentioned. Before installing the wings and deflectors there was a lot of air coming from below the fairing.
My problem is my shield isn't tall enough, so I get a lot of wind that way.
When in doubt, ride.
Karen
Boston MA
« Reply #5 on: November 15, 2011, 05:51:23 PM »
John, I cut some plastic out of my fork mounted deflectors in order to not hit the pods, and also have the Interstate Baker Air Wings mounted. Your post reminded me that I should put them back on, cause I do love that blast of wind during the hot weather. I'll take a look at them tomorrow, but cutting would be based on exactly where on the forks the deflectors are mounted. I keep the mounting hardware on the forks all year, just remove the deflectors. Bear in mind I'm a bigger fan of what works than of how it looks...
« Reply #6 on: November 15, 2011, 05:53:51 PM »
Have you thought about a winged wind deflector mounted on your fairing?  You might wanna consider these.  They're on the windshield web site that Glenn from Woody's fairings recommends for his fairings.
http://www.fastaire.com/Freedom-Wings.html
They're kinda like the Dragon wings from Kuryakn except way better looking and not as gawdy or expensive as the Kuryakyn wings.
http://www.kuryakyn.com/Products/839/AirMaster-Dragon-Wing
« Last Edit: November 15, 2011, 05:59:28 PM by BF » Logged
« Reply #7 on: November 15, 2011, 06:22:25 PM »
Wouldn't the Fastaire hit by Baker Airwings? I like the concept but...looks like without removing the triangle section they'll hit it.
I might try Karen's approach, also a fan of "do they work" as opposed to not looking perfect. Heck, with me on the back it already has a less than perfect appearance.  Wink
« Reply #8 on: November 15, 2011, 06:25:14 PM »
Did the fork think and made very little differance. Does help keep my hat on tho. You need the wings under your fairing. Esp since thats where the wind is coming from.  Wink The ones like BF posted are good. I got a set of wing deflectors and it took all my 'in the chest' wind away.
« Reply #9 on: November 15, 2011, 06:50:57 PM »
I don't know yet John.  I've got Bakers mounted on my bike......AND I've got a Woodys & the Fastair freedom wings that I've been trying to find the time to mount them since late this summer.  Maybe I'll get them mounted soon and then I'll know for sure....I hope.
John U.
Southern Delaware
« Reply #10 on: November 15, 2011, 08:18:09 PM »
I have these: http://www.bigbikethings.com/winddeflectors.html
They are a remake, more or less, of the Hondaline deflectors. They work well but I have to rotate them forward to avoid hitting the pods. That doesn't seem to reduce their effectiveness, though cutting/grinding them a bit narrower would help.
It's been a big improvement not having the wind try to stuff my beard up my nose.
Warlock
Magnolia, Ms
« Reply #11 on: November 16, 2011, 06:43:30 AM »
Never have been a I/S guy, but yours sure does look sweet.
David (Warlock)
« Reply #12 on: November 16, 2011, 07:42:28 AM »
With my Interstate, I find that a lot of influence on how the wind affects me is determined on how close I keep my thighs to the gas tank in combination with where I place my feet,, whether on the highway pegs or on the stock pegs.
I have cut my windshield down about three inches lower.
RTaz
Oscoda, Michigan
« Reply #13 on: November 16, 2011, 08:43:20 AM »
Thanks.
I have the show chrome fork defectors on it ....my wings were made for me by a guy at a GWRRA meet.
 RTaz
RTaz
Oscoda, Michigan
« Reply #14 on: November 16, 2011, 08:43:52 AM »
Thanks Warlock
 RTaz
NEHI
« Reply #15 on: November 16, 2011, 10:26:39 AM »
    I put the Showchrome fork deflectors on my I/S. It was by far the best inprovement I've done to the bike! Before my head shook so bad at anything over 40mph it gave me a head ache. I also put a Lamanar lip on and it also really helped. I'm 6'4" with a stock windshield, so I look out over the shield (The way I like it)
Flask
Inglis Florida
« Reply #16 on: November 16, 2011, 04:17:29 PM »
I used Memphis Shades #MEM 9887 brackets.
Cut my own deflectors out of aluminum plate - sculpted up into fairing to help block out as much air as I could - Had painted to match bike.
It took care of that air coming up your chest and into your face.
Let me know John - got plenty of aluminum plate - Yours would be sculpted different due to fairing difference.
« Reply #17 on: November 16, 2011, 05:24:19 PM »
Flask, that looks great. Per our phone conversation, I have the Nat'l. Cycle light bar and have Kury bullet lights hanging down for run/turn. That said, I'd have to cut a semi-circle out to clear them but shouldn't be a big task for Flask.  Wink  I'll probably meet up with my Titusville bud next week and get the Memphis fork brackets from him, give you a shout following that. That arm that extends out from the clamps...is also part of the Memphis brackets or did you fab those as well?
Those do look nice.
Flask
Inglis Florida
« Reply #18 on: November 16, 2011, 05:46:24 PM »
Those do look nice.
It is part of the bracket. Will be looking forward to your call.
« Reply #19 on: November 17, 2011, 07:11:45 AM »
Hey John, 1 good thing about your problem is no one can say ya'll is full of sheet in this case.   Laugh ya rascal.
 Evil Evil Evil cooldude cooldude cooldude tickedoff tickedoff tickedoff
« Reply #20 on: November 17, 2011, 10:19:21 AM »
Hey Russ, my resident bed warmer would disagree with you.  2funny  Just this morning I told her I need to lose 25 lbs. so I can see to polish my Sunday shoes. So what did she do....hand me a box of Dulcolax. She's so mean to me!  2funny Grin
justooneez
« Reply #21 on: November 17, 2011, 11:33:56 AM »
Wow flask, great job on those homemad :cooldude:e deflectors, best I've ever seen
Karen
Boston MA
« Reply #22 on: November 17, 2011, 05:57:53 PM »
ditto on that, flask, those are pretty!
Flask
Inglis Florida
« Reply #23 on: November 18, 2011, 10:00:56 AM »
I also made side covers and had painted two tone to match - along with painting pods also.
Thanks for the comments - To each his own - I just happen to like the paint in lieu of CHROME.
