February 03, 2026, 05:12:50 PM *
Author Topic: Airbox sealant?  (Read 1769 times)
lucky_1_chris
Arlington, TX
« on: November 19, 2011, 09:14:40 AM »
The glue that seals the tubes to the bottom of the airbox is shot. What sealant, if any, is recommended to replace it? Just some silicone around the outside?
1999 Valkyrie Interstate
olddog1946
Moses Lake, Wa
« Reply #1 on: November 19, 2011, 09:35:57 AM »
I would think silicone, RTV or most anything similar would suffice..there is or shouldn't be any pressure buildup to blow it out.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: November 19, 2011, 09:40:20 AM »
there is no need to re-seal the tubes,  by the time that you push/tug/pull installing the bottom back in, all you have done is to make a mess, and crack/split the sealant that you put on to start with.
lucky_1_chris
Arlington, TX
« Reply #3 on: November 19, 2011, 04:34:14 PM »
Thanks y'all. Ended up not needing to pull it, so I'm not gonna worry about it.
« Last Edit: November 19, 2011, 04:36:45 PM by lucky_1_chris » Logged
vic
East TN
« Reply #4 on: November 19, 2011, 07:02:10 PM »
According to the Honda Shop Manual for the Valkyrie, on Page 1-20 of the General Information Chapter, it states that material on the airbox tubes is Honda Handgrip Cement, so I don't think its really sealing the airbox tubes at all..
« Last Edit: November 19, 2011, 08:05:51 PM by vic » Logged
9Ball
« Reply #5 on: November 20, 2011, 04:25:44 AM »
the best guess and common consensus over the years is that the glue was only used during assembly line fabrication to hold the rubber pieces in position.  You do not need to do anything to replace.
Good luck...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
