February 03, 2026, 05:11:46 PM
Squeaking Noise
Topic: Squeaking Noise (Read 1769 times)
RUDE DOG - Steelers
New Jersey - VRCC # 3966
Squeaking Noise
November 20, 2011, 05:14:17 PM »
Since I put my I/S back together, I hear a squeaking noise while riding. Sounds like it coming from the center to rear of the bike. I only hear it while moving and going over a dip or bump. If Im just cruising there isnt any noise. Only over bumps. If Im stopped and bounce the suspension, I dont hear a thing. I had my buddy who is 260 bounce the rear while sitting and didnt hear anything. I did the complete rear end service while I had the back end apart as well as new wheel dampers. Not my first time doing this but I know Im not perfect either. Should I check the brakes? Loosen up the rear and retighten? Aside from that the bike runs perfect. Had it to 120 mph today and it was smooth.
Last Edit: November 20, 2011, 05:15:48 PM by STEELERS - Rude Dog
Re: Squeaking Noise
November 20, 2011, 06:51:54 PM »
Have you had the swing arm loose.
I over tightened one once and it squeaked.
RUDE DOG - Steelers
Re: Squeaking Noise
November 20, 2011, 07:09:40 PM »
No I didnt loosen thte swingarm.
PhredValk
Edmonton, Alberta, Canada
Re: Squeaking Noise
November 20, 2011, 10:34:35 PM »
Wheel bearings or brake caliper. Remove the wheel, check the bearings and clean out the brake caliper. Clean the brake rotor with brake cleaner while you're at it. If that don't work, bounce up and down to see if it's a shock.
Fred.
VRCCDS0237
Re: Squeaking Noise
November 21, 2011, 04:44:24 AM »
Mine squeaks once in awhile. Esp when the bike is dirty.
Re: Squeaking Noise
November 21, 2011, 07:05:04 AM »
Its hard to tell without being able to hear it, but, maybe a shock bushing ?
Re: Squeaking Noise
Reply #6 on:
November 21, 2011, 07:52:31 AM »
You can get a water pistol and ride.
Squirting water on different parts and areas will help to find the source of the noise if you have success in stopping the sound with a squirt or two.
The water will do no harm and it's an easy thing to do.
Re: Squeaking Noise
Reply #7 on:
November 21, 2011, 08:04:17 AM »
If you suspect the brakes.......lightly allpy brake pressure when you gover a bumpy patch that should make the bike make the noise......see if you can at least make the noise change if not stop with braking pressure.....if brakes makes no difference....others have had the dust ring not installed tightly and it was rubbing on the wheel
YoungPUP
Valparaiso, In
Re: Squeaking Noise
Reply #8 on:
November 21, 2011, 05:22:51 PM »
No mischevious passengers when this happens?
Victory Vision Squeaking Problem
powered by
Aeva
Sorry. Couldn't help myself. Heard once that smiling is good for headaches....
99 STD (Under construction)
