February 03, 2026, 05:11:45 PM *
Author Topic: clutch reservoir leaking  (Read 1527 times)
justooneez
« on: November 21, 2011, 03:23:56 PM »
I did something wrong again. Installed new galfer clutch line, no hitched, bleed brakes filled to fill line with clutch dismounted and held straight, installed float and rubber, then lid, reinstalled on handlebar and it is pouring out top under lid, afraid to tighten screws more, took off and checked rubber, no breaks or tears,  any ideas would be appreciated
Thanks, justin
justooneez
« Reply #1 on: November 21, 2011, 03:27:54 PM »
Nevermind, got it Smiley
justooneez
« Reply #2 on: November 21, 2011, 03:38:25 PM »
Well, Dang, nevermind the nevermind, still weeping a bit, but nowhere near as bad as it was, only when turned to the left all the way.  It's tight, and looked clean
DFragn
« Reply #3 on: November 21, 2011, 03:44:32 PM »
You only mentioned three parts, there are 4. The float, rubber boot gasket thingy, white plastic cap & then the reservoir screw cap.
Hope you get 'er fixed you don't want to ruin your tank paint with left turns.
The Anvil
Derry, NH
« Reply #4 on: November 21, 2011, 03:59:30 PM »
Put the white plastic cap and rubber boot together and THEN put them in the reservoir. Sometimes that rubber boot can get pushed down into the reservoir instead of sitting between them as it should.
Also, you may have fixed it and it may be residual fluid trapped under there weeping out. Hard to tell without seeing how much it is.
justooneez
« Reply #5 on: November 21, 2011, 06:16:23 PM »
yeah, thanks, finally got it weep free Smiley, I must be getting old, done this before, but never had a problem with it before, I think I was just taking things for granted, either that or was too excited about my new set of brake lines and clutch line  laugh
9Ball
« Reply #6 on: November 22, 2011, 05:03:18 AM »
Care to admit or enlighten about what the fix was?  Might be useful info to others in the future.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
justooneez
« Reply #7 on: November 22, 2011, 05:31:53 AM »
Went to reclean everything, and noticed that the lip of the master cylinder had some raised discolorations, drained the cyclinder and used a semi stiff dremel brush to smooth it down. Wouldn't think it would effect it, but, I guess take nothing for granted  Shocked
9Ball
« Reply #8 on: November 22, 2011, 05:36:08 AM »
thanks.....good job
1999 Standard
2007 Rocket 3
2005 VTX 1300S
The Anvil
Derry, NH
« Reply #9 on: November 22, 2011, 04:22:18 PM »
Ah, like a beige, caked on residue? I had the same problem. I recommend not eating raw cookie dough while working on your brakes.
Seriously though, I had the same buildup of crud.
