February 03, 2026, 05:11:44 PM *
Author Topic: rear wheel  (Read 2246 times)
teadream42
« on: November 23, 2011, 06:11:32 PM »
Hello dragon rider.
can a 2000 tour rear wheel fit a 98 stander. i just got one from pinwal and hoping to go to theDARK SIDE
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: November 23, 2011, 06:28:57 PM »
Hello dragon rider.
Yes.  Darkside away.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Disco
Republic of Texas
« Reply #2 on: November 23, 2011, 06:37:45 PM »
Yes, they are interchangeable.
I assume your new wheel did not come with the flange (part 8 in the picture), but if it did, do not use it with your final drive.  Take the one on the wheel you are currently riding, install it in your new wheel, and use it with your final drive.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
teadream42
« Reply #3 on: November 23, 2011, 06:42:17 PM »
yes. no flange nor brake disc.
thanks
« Reply #4 on: November 23, 2011, 07:22:25 PM »
thanks
Make sure you get the 2000 brake disk, if you try to use your 97 no workie
teadream42
« Reply #5 on: November 23, 2011, 08:05:14 PM »
I have a 98. why can I just put my brake disc on the new wheel.
Valkpilot
Corinth, Texas
« Reply #6 on: November 23, 2011, 08:09:34 PM »
thanks
I thought that only applied to the Interstate wheel 2000 and newer?  He's dealing with Standard and Tourer wheels and should be fine, regardless of the year.
« Last Edit: November 23, 2011, 08:23:13 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
teadream42
« Reply #7 on: November 23, 2011, 09:13:07 PM »
hi guys
i want to apologize for missing this but i just got an email from pinwall that i have bought an interstate 2000 not a 2000 tourer. and is there a fitting issue  uglystupid2
thanks for all the help.
tank_post142
south florida
« Reply #8 on: November 23, 2011, 09:17:05 PM »
97,98,99 standard and tourer use one rotor and caliper mount.
all  I/S as well as 2000 and up standard and tourer use a different rotor and caliper mount.
 if you are interchanging wheels between each series it is no problem ,but, if interchanging rotors, you must use the corresponding caliper mount or install a spacer to move the caliper mount to the correct relation with the rotor.
I got a rock Sad
VRCCDS0246
Disco
Republic of Texas
« Reply #9 on: November 23, 2011, 09:33:08 PM »
Thanks for the clarification, Tank.
Here are part numbers for rear wheel, rotor, and caliper bracket by year and series if you were to order them today.
All 1997-99 C & CT
Wheel Sub-Assy., RR. 42650-MZ0-670
Disk, RR. Brake          43251-MT8-000
Bracket, RR.              43110-MZ0-006
All Interstates, All 2000 C & CT, All 2003 C
Wheel Sub-Assy., RR. 42650-MBY-671
Disk, RR. Brake          43251-MBY-671
All 2001-3 CD
Wheel Sub-Assy., RR. 42650-MZ0-B21
edited to simplify and add rear brake caliper bracket part number
« Last Edit: November 24, 2011, 06:05:30 AM by Disco » Logged
78 CB550K
Valkpilot
Corinth, Texas
« Reply #10 on: November 23, 2011, 10:04:20 PM »
Thank you for this information.
I stand corrected.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
indybobm
Franklin, Indiana VRCC # 5258
« Reply #11 on: November 24, 2011, 06:36:18 AM »
thanks
Are you suggesting to not use the flange that comes with the wheel because of the existing wear pattern between the original flange and drive? Or is there another reason? Just curious, would not want to make a mistake in the future.
So many roads, so little time
VRCC # 5258
RP#62
Gilbert, AZ
« Reply #12 on: November 24, 2011, 07:08:30 AM »
May be a fluke, but I put a newer style wheel on my '97 and it fit no problem with the original caliper, but I changed the wheel and rotor as an assembly.  That is I keep the rotor together with the wheel it came on and as long as I change them as an assembly, I haven't had any problem with them fitting either bike.
-RP
Disco
Republic of Texas
« Reply #13 on: November 25, 2011, 08:07:51 AM »
Yes, exactly.
Thanks, RP.  I believe I've heard that before, but wasn't sure.
78 CB550K
« Reply #14 on: November 25, 2011, 01:30:25 PM »
-RP
The older disk has a thinner center portion.  The older wheel has a longer (laterally) hub.  The newer wheel has a slightly shorter hub and a thicker disk center portion.  Keep new and new together and it will fit on the older bike......keep old and old together and it will fit on a newr bike......mix old wheel and new disk=problems and vice verse
