February 03, 2026, 05:11:41 PM *
Author Topic: VALKYRIE BRAKE AND CLUTCH LEVERS  (Read 2383 times)
RONNIEB
NEWCASTLE, OKLAHOMA
« on: November 24, 2011, 06:23:51 PM »
SINCE OUR "FAT GIRLS" HAVE ALOT IN COMMON WITH GOLDWINGS, WILL THE ADJUSTABLE LEVERS FROM A 'WING FIT THE VALKS?
1999black standard; 2000 black tourer; 1999 red/black interstate
BonS
Blue Springs, MO
« Reply #1 on: November 24, 2011, 07:36:51 PM »
The short answer is yes. There is a single cut that you have to make on one of them though. I took a quick look through shop talk but didn't see it there. Someone will come along that knows the details.
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: November 24, 2011, 08:17:17 PM »
There's a tab that needs to be cut off of the clutch lever; see
http://forums.delphiforums.com/valkyrie/messages?msg=13360.1
I also found that my brake light would stay on unless I pushed the lever with a finger. A member (can't remember who, but am eternally grateful) told me to grind off a bit on the bottom of the brake lever because it pinches. Look on the bottom of the brake lever, you'll see a raised circle of metal, about 2mm high. I ground this off and the lever works perfectly.
Fred.
« Last Edit: November 24, 2011, 08:21:41 PM by PhredValk » Logged
VRCCDS0237
« Reply #3 on: November 25, 2011, 04:48:48 AM »
But, its the 1800 Wing levers we are talking about.  The chrome wide blade ones
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #4 on: November 25, 2011, 10:50:37 AM »
THANKS FOR THE REPLIES. I'M 45 AND GETTING SOME ARTHRITIS IN SOME HANDS THAT HAVE BEEN BROKE UP AND HAVE MORE MILES THAN YEARS. THERE IS A SET OF LEVERS IN J&P CATALOG THAT MAY BE COMING TO MY HOUSE. I HAD TO GET THE WIDE LEVERS FOR MY 07 SHADOW SPIRIT AS THE ORIGINAL ONES FELT LIKE THEY WERE SEPERATING MY FINGER JOINTS HOLDING THE CLUTCH AT STOPLIGHTS. OK, I'M A WIMP HAHA
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #5 on: November 25, 2011, 11:54:07 AM »
just ordered the wide levrs from wingstuff, we'll just wait and see how they work.
« Reply #6 on: November 26, 2011, 08:34:04 AM »
Nowhere does it say, you cannot put the bike in neutral, while at a stoplight.
Farther
Quimper Peninsula, WA
« Reply #7 on: November 26, 2011, 10:55:06 AM »
And off we go!!
~Farther
Ken Tarver
North Mississippi
« Reply #8 on: November 26, 2011, 02:09:44 PM »
no to neutral at the light ! unsafe
sidecarrick
VRCC 13089
windsor,ontario,canada
« Reply #9 on: November 26, 2011, 03:19:49 PM »
Agreed!! I've had more than 1 quick escape that would have been impossible if the bike were in neutral.
