February 03, 2026, 05:12:52 PM *
Author Topic: Drive shaft info please  (Read 1986 times)
tmfp
The south west of England
« on: November 25, 2011, 01:19:38 PM »
I am contemplating extending the rear of my 97 by 3 inches. I haven't yet pulled everything apart and am finding it difficult to get an image of the basic shaft itself. The fiches I have are no help.
I got this, of a 1500 'wing assembly, is ours similar and has anyone stripped one completely down?
Any pics or experience would be most welcome.
« Last Edit: November 25, 2011, 02:36:18 PM by tmfp » Logged
« Reply #1 on: November 25, 2011, 02:45:33 PM »
The yoke side is correct, but the Valk doesn't have a universal on the other end, that is where the drive shaft plugs into the pinion cup.
keepinon
New Caney, Tx
« Reply #2 on: November 25, 2011, 03:25:11 PM »
On the earlier wings (pre-1997) the drive shaft is 1-1/2" longer than the Valk shaft. Splines front (u-joint) & rear (cup) are identical. The tension spring is also the same on both shafts.
The shaft pictured looks like it came from a trike.
1998 GL1500 CT Trike
tmfp
« Reply #3 on: November 25, 2011, 09:46:02 PM »
Excellent, thank you.
It was in the fiche all the time, under swing arm, not drive shaft  uglystupid2
