February 04, 2026, 05:15:39 AM *
Author Topic: Galfer brake lines came in.... Gotta question.  (Read 2503 times)
Bugslayer
Lubbock, Texas
« on: December 09, 2011, 04:40:50 PM »
My brake lines came in, and they look great! I've got a question, though.
On the front set, there are two "fittings" that the right and left brake line screw into. There is also a short cross over line that also screw into them. My question is, should anything be used on the threads to keep them from leaking and get a good seal? Or should I use threadlock?
I e-mailed Galfer with no reply. Today I called their customer service and talked to a lady.... who said she would give their "tech service" my message. Of course, no call back. Go figure.
Thanks.
« Reply #1 on: December 09, 2011, 04:57:13 PM »
don't put anything on the threads, it could contaminate the fluid. sealing washers should be used.
on a side note, there is actually no such thing as thread sealer, ie, teflon tape, pipe dope, neither actually provide much sealing, their job is to provide lubricant to the threads to allow the threads to engage deeper into the taper. the threads are actually what provides the sealing for taper pipe threads.
quexpress
Montreal, Québec, Canada
« Reply #2 on: December 09, 2011, 04:58:40 PM »
Thanks.
I have used teflon tape on mine without any problems. As previously mentioned, it might not have been required ... but gave me peace of mind!  Smiley
« Last Edit: December 09, 2011, 05:00:43 PM by quexpress » Logged
I still have a full deck.
I just shuffle slower ...
Bugslayer
Lubbock, Texas
« Reply #3 on: December 09, 2011, 06:04:54 PM »
That makes sense. Thanks.
The only washers that came with the set are the crush washers for the banjo bolts. After looking closer at how the threaded ends go into the fittings, it looks like the very end (the part the treads rotate on) will seal the lines.
Thanks again.
Bugslayer
Lubbock, Texas
« Reply #4 on: December 09, 2011, 06:09:03 PM »
 [/quote]
[/quote]
It looks like it'll work without putting anything on the threads. Now if my garage wasn't one big freezer, I'd be out there putting them on.  tickedoff
 Thanks for the reply!
mikochan
Syracuse, NY
« Reply #5 on: December 10, 2011, 09:07:14 AM »
I was looking mine over today and was wondering how they are going to mount on the forks? Do we have to get new nuts and bolts or can we reuse the existing?
To cold here now to start replacement.
The Anvil
Derry, NH
« Reply #6 on: December 10, 2011, 09:18:16 AM »
Are they dual (as in; two separate ones coming out of the master cylinder with a common banjo bolt) lines or a y type line?
I have a Y type line (one line coming off the MC that branches off just below the lower triple clamp to go to the left caliper) and I used adel clamps (available at any parts store) in the stock bolt holes on the bottom of the lower triple clamp normally used for the OEM manifold to hold the line in place. I then cut the rubber grommets off of the stock lines and re-used them on the fender brackets.
If you have dual lines you can get a little creative with the adel clamps and still use the stock manifold bolt holes. I'll get some pics later of that area if you want.
Adel clamp:
mikochan
Syracuse, NY
« Reply #7 on: December 10, 2011, 11:28:16 AM »
There are actual 4 hoses and 2 metal "connection blocks". The blocks are suppose to mount on each fork with a short hose in between and hoses going to the MC and calipers.
I think a will need to get some SS bolts and nuts to mount the "blocks".
thanks
The Anvil
Derry, NH
« Reply #8 on: December 10, 2011, 02:20:24 PM »
So they're like the stock setup but with threaded blocks and fittings instead of swedged junction points? If that's the case the you should be able to use the stock manifold bolts and adele clamps along with the stock fender brackets.
Bugslayer
Lubbock, Texas
« Reply #9 on: December 14, 2011, 11:17:43 AM »
thanks
I'm in the process of installing my Galfer lines. When you take off the stock system , you'll need to remove the mounting brackets that attach the stock line to the forks. Those brackets  will go back where they came from on the forks, and the new blocks will mount to the brackets. I did have to get two SS bolts, washers & nuts to mount the blocks to the brackets.
« Last Edit: December 14, 2011, 12:15:39 PM by Bugslayer » Logged
fordmano
San Jose, CA.
« Reply #10 on: December 15, 2011, 09:21:30 PM »
Here are a couple pictures that might help a tiny bit. I used the stock brackets but like you picked up some longer Stainless bolts.
After I looked at the picture a while I guess they won't help much,,, but I haven't done any real changes lately so I figured I would leave them here and share them again...
Oh and the link to all my upgrade and maintenance pictures from the last 1.5 years or so.
http://s974.photobucket.com/albums/ae222/fordmano/Valkyrieupgradeprojects2010/
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
GJS
Today is the tomorrow you worried about yesterday.
Vancouver Island, BC, Canada
« Reply #11 on: December 16, 2011, 12:03:17 PM »
[/quote]
Fordmano,
I love your extended piggies!
Where did you get the extensions?
Cheers,
Glenn
The tragedy of life is not that it ends so soon, but that we wait so long to begin it.
- W. M. Lewis
« Reply #12 on: December 16, 2011, 02:31:49 PM »
fordmano, I thought there was something I was missing, looking forward to posts for your project.
You need to go out and buy another bike and start another one...  hmmmm... I need a bike, there is a nice one in CA right now, with the CB and blue/silver I want...... I have to ship from CA, so I wasn't going to buy from there, but I don't know how a private sale needs to progress.
JC
The Beast
Franklin, TN
« Reply #13 on: February 23, 2012, 06:01:19 AM »
Tried installing my new Galfer lines on the front and couldn't get them to stop leaking at the crossover. Ended up tightening them too far and......... snap!  Embarrassed
Learned an expensive lesson there. They MUST have sealing washers, don't attempt to install the lines without them. Now if I can just find another crossover line and T fitting............
Bugslayer
Lubbock, Texas
« Reply #14 on: February 23, 2012, 12:23:52 PM »
That sucks. Sorry about your bad luck.
The only washers on my Galfer system are on the banjo bolts. The crossover line dosen't have any washers, and they haven't leaked a drop.
« Reply #15 on: February 23, 2012, 06:33:57 PM »
They wont leak either they bottom out and they are cone shaped at the bottom so they seal perfectly. The banjo gets copper washers. Just a tip Wink put some clear silicone on the ends of the lines that are  clamped to the fitting. Let me explain a bit better the lines have a clear coating over the stainless braid. The clear coating doesnt meet the crimped on end and the stainless is open to the elements at this point. If you wash the bike or are in any kind of weather the water gets in there and makes the line look really bad. It supposed to be stainless so you think it wouldn't matter but it does rust. If you take a little clear silicon and cover this area then water doesn't get in between the plastic and the stainless braid.
« Last Edit: February 23, 2012, 06:37:31 PM by Robert » Logged
« Reply #16 on: February 23, 2012, 06:40:24 PM »
JC I may have anther crossover line that I took off my bike when I replaced my lines. Ill look and just post if interested also Galfer may even ship you a line at no cost of minimal cost if you call them.
JC
The Beast
Franklin, TN
« Reply #17 on: February 24, 2012, 06:31:48 AM »
Thank you Robert! If you have one I'd be much obliged, drop me a PM if you find it. I did call Galfer and they will sell individual parts, so at least it's not a lost cause.
