February 03, 2026, 06:46:56 PM
Tire Recommendations?
Topic: Tire Recommendations? (Read 1342 times)
CowboyBlue
Saint Louis, MO USA
December 12, 2011, 12:37:56 PM »
I am the proud as pie owner of a pristine 1999 Valk Interstate. She needs new rubber.
So, any advice? I'm a long distance rider (not ready for the dark side yet). Can I increase the width of the rear and lower the height? I'm short and need about an inch less seat height.
I think I want Metzlers, but my Shadow has done excellent with Continentals.
Re: Tire Recommendations?
December 12, 2011, 01:33:42 PM »
You won't find any continetals that are the correct size. I use Dunlop bias tires. Hoser
moreira72
VRCC# 33494
Clark, NJ. 07066
December 12, 2011, 02:53:14 PM »
Metzelers front and rear (radials)
150/80/17 in the front
200mm out back no rubbing issues.
Stock shocks are 13" long, so you will have to get 12.5 or 12" to lower rear
99 Interstate 26K
John U.
Southern Delaware
December 12, 2011, 03:44:52 PM »
I know it's been discussed before but I'm curious to know the good and especially the not so good aspects of 200/60 rear tires.
I know they will fit, what about cornering, braking, ride height, tire longevity, etc. I'd like to know what I'd be getting with a 200 beyond "it's wider and looks cool", which of course it is and does.
Thanks in advance
Challenger
December 12, 2011, 03:51:57 PM »
Cowboy: if you just want to lower a little, the 1800 Gold-wing tire is a 180/60/16 instead of a 180/70/16 for the Valk. John U: I had a 200 Metz on my Std for a while, Not much difference in handling but it only lasted 5100 miles. 42 psi and solo a lot, It was paper thin when I took it off, But then again I only get 8 to 9000 out of Avons or Bridgestones. YMMV.
December 12, 2011, 05:28:02 PM »
I'd put a set of OEM size Elite III's on it and call it a day. Then go shopping for a shorter seat and shorter shocks. Have you considered an Ultimate Lo Boy and/or a set of 11.5 or 12 inch Progressive or Works shocks?
Reply #6 on:
December 12, 2011, 07:15:47 PM »
conti on the front, E3 on the rear.
http://www.valkyrieforum.com/bbs/index.php/topic,12541.40.html
first try, a narrower seat which will bring your legs closer to the ground better than a lower seat.
