August 21, 2025, 08:41:38 AM *
Author Topic: Question about hoses and clamps  (Read 1494 times)
Fritz The Cat
« on: January 03, 2012, 08:23:53 AM »
Just bought some 1/4 inch fuel line hose (says so right on the hose). Stupid auto parts store didn't have any spring clamps and the idiot never heard of them. So I have to order them on line. Not a problem but I have know what size clamps fit a 1/4 inch hose. the inside diameter is 1/4 inch. The outside diameter is 7/8 inch (as measured with a ruler). A 7/8 inch clamp will be the same size as the hose so it won't work.
Will a 3/8 inch clamp work? If not, what size clamp do I need? Pardon my ignorance, I was never any good at math.  uglystupid2
« Reply #1 on: January 03, 2012, 08:33:10 AM »
Have you got any other parts houses to deal with besides the one you bought the hose at. Wally world local garage neighbor old stuff in your tool box??? RIDE SAFE.
Fritz The Cat
« Reply #2 on: January 03, 2012, 08:39:23 AM »
CORRECTION, the OD is 7/16, not 7/8. Like I said, I'm no good at math.  Embarrassed
Fritz The Cat
« Reply #3 on: January 03, 2012, 08:48:42 AM »
Here's what they look like.
Bone
« Reply #4 on: January 03, 2012, 09:18:15 AM »
I have never bought that type of clamp. So I'm guessing a 1/4 inch clamp would fit a 1/4 inch OD hose as tight as necessary to clamp the hose on a fitting. If they were labeled according to the ID you would have to know the thickness of the hose wall.
Fritz The Cat
« Reply #5 on: January 03, 2012, 09:40:46 AM »
The hose is clearly labeled "1/4 inch fuel line hose" but this refers to the inside diameter.
The grist of the matter is, I have to order these clamps and would rather get the right ones the first time as  I'm probably looking at minimum a week to get them. If I order the wrong ones, it's another week. Hence my question. Surely there is an answer out there somewhere. It may very well be that a 7/16 clamp is made to fit a 7/16 hose, etc., etc. But I don't know this.
And btw, these clamps are sized 1/4, 3/8, 1/2, etc. I just don't know if this refers to the actual size of the clamp or the hose size it's made for.
Bigwolf
Cookeville, TN
« Reply #6 on: January 03, 2012, 09:53:51 AM »
I just did a search and come up with some sizing details for spring clamps.  Check out these links.  I believe you will find all you need to know here.  http://www.rotorclip.com/cat_pdfs/ctb.pdf  http://www.rotorclip.com/hose_clamps.php
Wolf
JetDriver
Columbus, OH
« Reply #7 on: January 04, 2012, 07:20:08 AM »
You could also send a question to the supplier you're dealing with.
« Reply #8 on: January 04, 2012, 07:44:15 AM »
Every time I remove that type of clamp for whatever reason, it never goes back on. I'll replace it with a screw type, especially on a fuel line or any line that handles a liquid.
« Reply #9 on: January 04, 2012, 09:08:37 AM »
Yep,,,,, an besides it's too difficult to get a pliers in under the tank for those spring clamps.
Fritz The Cat
« Reply #10 on: January 05, 2012, 04:42:52 AM »
UPDATE -
I should have mentioned that this is for a Honda ruckus. It's pretty tight in the engine compartment so I think the spring loaded clamps are the best choice. These are made of spring steel so they're as durable as they can possibly be. I decided to order the Honda OEM "Tubes" instead of using standard fuel line. I was concerned about the two 45 degree turns these make in tight quarters. Also, I bought an assortment pack of these clamps so I'll be able to zero in on the correct size. The Honda OEM clamps are one use and made of wire that has no spring to it at all. Sorriest hose clamp I've ever seen, hence me wanting to replace them with these much much sturdier clamps.
BonS
Blue Springs, MO
« Reply #11 on: January 05, 2012, 06:41:47 AM »
I've found spring clamps at O'Reillys Auto Parts in a blister pack hanging on the shelf. It is an assortment of about 8 pieces. Bypass the store clerk and study the shelves and probably most any auto parts store will have these.
Fritz The Cat
« Reply #12 on: January 05, 2012, 10:17:35 AM »
Of the 4 local auto parts stores in the area, O'Reilys was the one I didn't go to because it was way on the other side of town. Nice to know that they have them in case I need more.
