March 28, 2026, 08:37:57 AM *
Author Topic: Anyone know the answer to this question?......  (Read 862 times)
Stanley Steamer
Athens, GA
« on: January 03, 2012, 03:05:54 PM »
I want to know how many WATTS this 90Amp welder uses?......I'm not sure how to convert it and I didn't see it on the website..... Sad
http://www.harborfreight.com/welding/mig-flux-welders/90-amp-flux-wire-welder-98871.html
What I'm wondering is if this little generator would run the above welder if a man couldn't get to an A/C outlet?.....at least on the minimum setting of 45amps......
http://www.harborfreight.com/800-rated-watts-900-max-watts-portable-generator-66619.html
Stanley "Steamer"
"Ride Hard or Stay Home"
gregc
Media Pa.
« Reply #1 on: January 03, 2012, 03:16:43 PM »
I believe you divide watts into volts to get amps.   But that welder works off a step down transformer, so i don't think that formula will work.
Daniel Meyer
The State of confusion.
« Reply #2 on: January 03, 2012, 03:28:05 PM »
Manual downloaded from that page says 24A Peak @120V
That's 2880 watts...
I would expect it draws less for most welding at lower settings, but startup may spike that high even on lower settings...
Half power (45amp setting) *should* draw somewhere close to half the watts, but there are fans/etc that don't figure into that.
So, I don't think you could run it effectively on 900 watts.
CUAgain,
Daniel Meyer
Bigwolf
Cookeville, TN
« Reply #3 on: January 03, 2012, 03:29:47 PM »
The advertised power input to that welder is 120 volts and up to 20 amps.  The conversion for watts is amps times volts so that makes this welder 2400 watts.  The generator is only 800 watts with a momentary surge rateing of up to 900 watts.  No, this generator will not safely run that welder.
Wolf
Stanley Steamer
Athens, GA
« Reply #4 on: January 03, 2012, 03:30:16 PM »
I didn't think so......thanks
Stanley "Steamer"
Stanley Steamer
Athens, GA
« Reply #5 on: January 03, 2012, 03:31:42 PM »
I got that little generator for Christmas....MAINLY for running a drill at remote locations when I'm doing crosstie work..... cooldude
Stanley "Steamer"
Bigwolf
Cookeville, TN
« Reply #6 on: January 03, 2012, 03:52:31 PM »
I did not read the manual, just the main ad page.  Daniel was a bit more thorough than me on that one.
Wolf
Jess Tolbirt
White Bluff, Tn.
« Reply #7 on: January 03, 2012, 04:27:12 PM »
i am an electrician and the answer is NO, probably wont even strike an arc,,,
Valkyrie member # 23084
