February 04, 2026, 03:32:05 AM *
Author Topic: No side stand light  (Read 2611 times)
Jruby38
Oxford Mass.
« on: January 12, 2012, 04:37:56 PM »
My side stand light stopped working. I took the cover off the, but I don't see a bulb for it.
tank_post142
south florida
« Reply #1 on: January 12, 2012, 09:24:51 PM »
it may be the side stand switch. try starting it in gear with the stand down.
I got a rock Sad
VRCCDS0246
alph
Eau Claire, WI.
« Reply #2 on: January 13, 2012, 03:49:53 AM »
that's what i'd say.  i know that on the I/S the warning lights are LED so it's not likely to burn out.
Jruby38
Oxford Mass.
« Reply #3 on: January 13, 2012, 06:24:40 AM »
Stand switch works, Kills the motor.  The bike is a 99 standard and the small yellow light is in the tach next to the other idiot light that all work.  Is it an LED?
Bone
« Reply #4 on: January 13, 2012, 07:30:00 AM »
The manual has the meter lights at 12v 1.7w. Same for Tach and speedometer.
Pull the bulb before you order.
« Reply #5 on: January 13, 2012, 07:35:33 AM »
This is news to me!
Are you saying there is a light that illuminates when the key is on and the side stand down?
There is nothing on the Interstate like what you are talking about.
Bone
« Reply #6 on: January 13, 2012, 07:52:37 AM »
Ricky-D that light helps if the starter doesn't spin when you push the button.
Jruby38 Dag has some bulb info at his site. http://www.valkyrienorway.com/partsbulb.html
Here is some info I had saved;
AND if you want brighter or a different color for background on your gauges, check out superbrightleds. they have led replacements for the 194 wedge bulbs. Here's the page   http://www.superbrightleds.com/mini-wedge.html
If it is a standard or tourer, I put in 194LL or 168LL (LL = Long Life) one of the 2 was brighter then the other, and that was the one I used.  Sorry I don't remember which of the 2 it was, but they are really cheap bulbs.  I think all 4 cost less then 3 bucks.
« Last Edit: January 13, 2012, 07:57:29 AM by Bone » Logged
bscrive
Ottawa, Ontario
« Reply #7 on: January 13, 2012, 08:04:25 AM »
I am with Ricky-D on this,
I have an Interstate and I don't have a side stand light on it.  Is this an aftermarket item that you put on?
« Reply #8 on: January 13, 2012, 08:05:38 AM »
What light would that be?
Is this something that only the Standard or Tourer has?
Or is it maybe something that is an aftermarket device added to the bike?
Bone
« Reply #9 on: January 13, 2012, 08:09:06 AM »
It's a indicator light in the tach face. I don't remember the color. It's snowing and blowing I won't go out and look right now Smiley
Bone
« Reply #10 on: January 13, 2012, 08:13:38 AM »
It's yellow Jruby38 has it in his post.
jmann
Mesa,Az.
« Reply #11 on: January 13, 2012, 08:14:28 AM »
I have a 98 tourer and I have a side stand light. Yellow/orange color bottom right of tach.
« Reply #12 on: January 13, 2012, 08:45:19 AM »
Ok, I just found it in a wiring schematic for a Tourer.
It is supposed to light up when the key is on and the side stand is down.
Seems having to depend upon a light to tell you the kickstand is down is an insult to american intelligence by the Honda designers.
And I can't see any connection to the starting system except that the light may go out as like with the headlight when you depress the starter button.
YoungPUP
Valparaiso, In
« Reply #13 on: January 13, 2012, 09:09:17 AM »
Check the side stand switch again. My side stand light quit working, but would still lock out the starter if the bike was in gear.
99 STD (Under construction)
Bone
« Reply #14 on: January 13, 2012, 09:17:13 AM »
Maybe just an insult to bikers.
Jruby38
Oxford Mass.
« Reply #15 on: January 13, 2012, 09:49:41 AM »
So it just one of those flashlight looking bulbs?
WamegoRob
Wamego, KS
« Reply #16 on: January 13, 2012, 11:32:19 AM »
Bottom right... S = Side Stand
Bone
« Reply #17 on: January 13, 2012, 11:55:47 AM »
Not a very good pic they are the wedge type bulbs.
« Reply #18 on: January 13, 2012, 02:10:07 PM »
It was a std that he had.
If the side stand works, then it would be your light only.
BradValk48237
Oak Park, MI
« Reply #19 on: January 13, 2012, 02:22:34 PM »
I agree... Have an I/S and I don't see now stinkin light.....
Should there be one?
Brad
RP#62
Gilbert, AZ
« Reply #20 on: January 13, 2012, 05:19:01 PM »
Interstate's don't have a side stand light, only Standards and Tourers.  The wedge bulbs mentioned are for illuminating the gage face, they aren't the indicator bulbs.  I haven't had mine apart, but I'm pretty sure the indicator lights are LEDs.  There's a white 9-pin connector in the headlight shell.  The yellow wire with the black trace is the wire coming from the side stand switch going to the side stand indicator light.  When you put the side stand down, it provides a ground to the light to turn it on.  If you take the connector apart, you should be able to jumper a ground to the yellow wire with the black trace and turn the light on if its good (ign needs to be on when you do this).  If it comes on, you're loosing the ground somewhere between the connector and the switch (probably the switch, it gets grungy.
Let us know what you find.
-RP
Bone
« Reply #21 on: January 14, 2012, 03:34:48 AM »
Thanks RP#62 I knew where the wedge bulbs went wasn't thinking I guess. I don't have a number for the indicator bulbs will look for one.
RainMaker
Arlington, TX
« Reply #22 on: January 17, 2012, 03:13:56 PM »
The I/S don't have the sidestand light but doesn't need one.  When you put the bike in gear with the sidestand down, it shuts off the motor.  Makes it very idiot proof.  A real plus for me. 2funny
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
« Reply #23 on: January 18, 2012, 06:10:39 AM »
With all Valkyries, the side stand being down will not allow the motor to be started without the transmission being in neutral. The clutch lever (switch) has no affect in this particular situation.
« Reply #24 on: January 31, 2012, 05:34:17 PM »
Now that we know which bikes have side stand lights, LET'S MOVE ON with the install of superbrightleds in the speedo and tach, they're great!    Cool  coolsmiley  cooldude
My rides:
Brian
Monroe, NC
« Reply #25 on: February 01, 2012, 07:18:37 PM »
Ditto salty1. The cool whites really make a difference.
