February 04, 2026, 01:35:37 AM
Neutral problems...
Topic: Neutral problems... (Read 1771 times)
Alien
Ride Safe, Be Kind
Earth
Neutral problems...
January 15, 2012, 08:57:53 AM »
Over the past few months, it's been getting harder and harder to get my neutral light to come on. There's no problem getting the transmission into neutral, just a lot of fiddling with the shift lever to activate the light.
In the 7 years that I've owned my Valk, it has only started in neutral (With the neutral light activated). I didn't realize that this wasn't normal until I read plcae's thread below. I'll be addressing the clutch lever/switch shortly.
Two questions:Is the neutral light switch servicable? Where is it located? I'm thinking that it's dirty or worn. I remember removing and cleaning the switch in my 74 CB750...but that was a while back.
YoungPUP
Valparaiso, In
Re: Neutral problems...
January 15, 2012, 09:17:49 AM »
Here's my post from earlier. You're not alone with this one.
http://www.valkyrieforum.com/bbs/index.php/topic,28874.msg263694.html#msg263694
99 STD (Under construction)
Alien
Ride Safe, Be Kind
Earth
January 15, 2012, 09:26:14 AM »
Quote from: YoungPUP on January 15, 2012, 09:17:49 AM
Thank you!
Bone
January 15, 2012, 09:38:25 AM »
From the Service manual;
NEUTRAL SWITCH
INSPECTION
Remove the right steering side cover (page 2-51.
Disconnect the 4P (red) connector and check for continuity
bemeen the tight green/red wire terminal of the engine
sub-harness side cunnector and ground.
There should be continuity when the transmission is in neutral
and no continuity when the transmission is in any other gear.
REMOVAL / INSTALLATION
Remove the transmission cover (page 10-51.
Remove the wire grommet: from the cover groove.
Remove the bolt and wire retainer.
Remove the two bolts and the neutral switch.
Tnstallation is in the reverse order of removal.
TORQUE: 12 N-rn (1.2 kgf.rn, 9 Ibf-ft)
Apply sealant to the seating surFace of the grommet.
Alien
Ride Safe, Be Kind
Earth
January 15, 2012, 10:26:30 AM »
Great! Thanks for the info! I owe you guys a beer at InZane.
RP#62
Gilbert, AZ
January 15, 2012, 11:43:21 AM »
Always better with pictures (not mine but from a post many years ago).
-RP
Cattman
Franklin, IN
Reply #6 on:
January 15, 2012, 01:34:18 PM »
Pull your clutch lever and see if the hole in it is getting oblong. I replaced clutch switch and sidestand switch before discovering this was the problem.
