January 28, 2026, 03:24:51 PM *
Author Topic: Audiovox cruise question  (Read 2251 times)
Kingbee
VRCC# 576
Northern Illinois
« on: May 10, 2009, 10:09:54 AM »
Is there any real reason why one wire is supposed to go to the battery, as opposed to being switched?  That just doesn't make sense to me.  Or, was it a literal interpretation from the automotive instructions, that possibly for convenience, two wires go to the brake switch - one to the switched side, and one to the hot side?
Unless someone has a good reason, I'm going to all switched.
1999 Interstate
2000 Interstate
2004 Rune
hardhead
Lone Oak, KY
« Reply #1 on: May 10, 2009, 10:44:10 AM »
I wondered about that too.  Hooked mine to the battery with an inline fuse.  After some thought, it is probably a safety measure so that if there is no power to the brake lights to cancel the cruise, it can't be engaged.  I think I'll go back and change mine.
BOZ
« Reply #2 on: May 10, 2009, 12:21:45 PM »
I run that "battery" wire to a switched lead. No problem. Works fine and makes more sense to run it to a switched lead.
Kingbee
VRCC# 576
Northern Illinois
« Reply #3 on: May 10, 2009, 01:07:51 PM »
Thanks Boz, that's what I needed to know.........
1999 Interstate
2000 Interstate
2004 Rune
« Reply #4 on: May 10, 2009, 01:52:56 PM »
Tied them together to a switched source....an extra fuse panel under the right side cover. Been that way for about four years with no problems.
