August 21, 2025, 06:12:05 AM *
Author Topic: Clutch lever bushing  (Read 2348 times)
F6BANGER
Albuquerque NM
« on: January 24, 2012, 02:09:34 PM »
Im trying to figure out my clutch issues... Angry  Did some searching on the bushing and read multiple times about the bushing. It can go "oblong". My push rod #1 fits fairly tight in the bushing #2.
http://www.hdlparts.com/fiche_section_detail.asp?section=148534&category=MOTORCYCLES&make=HONDA&year=1999&fveh=3473
How loose is too loose?
Symptoms of clutch:
Starting off in first gear, sometimes I get chatter, not always.
Clutch Lever WILL pull all the way to grip.
Bike sometimes starts to move the instant I begin releasing the lever. Other times I can let it out 1/4 of the way before it grabs.
The clutch lever has a little play before I feel pressure as I pull it in.
While moving, if I let the clutch out slowly, it doesnt go all the way out. Kinda like sticking. If I let it out fast, it goes all the way out.
Every once in a while while kinda gettin on it, the clutch slips, and it slips like a mutha. I let off on the throttle and ease back on it and have no slipping..
I have already removed and cleaned the clutch master cylinder and bled the line using a mighty vac. Still having the problem. Gonna pull and clean the slave cylinder and add dot 4 with mighty vac.
Guessing Im gonna have to do the inevitable....Prolly the rivits....
Any suggestions?
hrapp
Rosharon,tx
« Reply #1 on: January 24, 2012, 02:15:53 PM »
i had a problem with the brass bushing wearing oblong, watch the wear on the handle too. don't let it go too long or you'll be buying a handle. the dealer sells those bushings for about $10 bucks. i made mine out of brass and drill reamed to fit the pushrod. just like new again. if your handle rattles, its probably time to replace the bushing.
1997 valkyrie tourer
1972 shovel
2009 vtx 1300r
1995 sportster
hrapp
Rosharon,tx
« Reply #2 on: January 24, 2012, 02:19:55 PM »
clutch slipping? what kind of oil you using? don't use anything with moly in it.
1972 shovel
2009 vtx 1300r
1995 sportster
F6BANGER
Albuquerque NM
« Reply #3 on: January 24, 2012, 02:26:29 PM »
My levers are Kuryakyn with brass bushings that the screw goes through. They are in great shape. The bushing that the pushrod goes in is fairly tight. You got a pic or your worn out bushing?
« Reply #4 on: January 24, 2012, 03:12:00 PM »
Is it all clean back there? No bugs or road grime caked on is it? Mine was and a little cleaning and lub I was good to go.
« Reply #5 on: January 25, 2012, 11:21:38 AM »
I don't think your symptoms can be explained as a lever issue.  The rivet theory makes the most sense to me, especially with the unpredictable engagement point.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #6 on: January 25, 2012, 12:22:48 PM »
+1
If you get to the point that sometimes you can't pull the lever all the way to the grip, it's a near certainty that the rivets in the damper plates are shearing.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Sodbuster
« Reply #7 on: January 26, 2012, 04:45:36 PM »
so ........ is the rivet issue a somewhat common issue or is that caused by burnouts and other types of abuse ??
VRCC # 30938
« Reply #8 on: January 26, 2012, 05:06:43 PM »
it was posted about 2 yrs ago that a certain suzuki bushing is an exact fit for about $4. a search should bring it up.
Bone
« Reply #9 on: January 26, 2012, 05:41:44 PM »
Valk clutch lever bushing
Suzuki part number 59892-08A00   $3.05
Honda part Number 2285-MBO-006   $10.00
Valkpilot
Corinth, Texas
« Reply #10 on: January 26, 2012, 06:12:17 PM »
It seems to occur most frequently on '97s and '98s in the 60k to 70k range.  Allegedly, the problem is caused by sub-par components from a sub-contractor.
Usually the friction plates are in fine shape, but since it's apart already...
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #11 on: January 26, 2012, 06:26:24 PM »
If the lever bushing is worn, it will be obvious, deformed and lotsa play in the lever.  Cheap & easy to replace.  Should be able to tell at a glance if it's needed.
Michael K (Az.)
Glendale, AZ
« Reply #12 on: January 27, 2012, 07:53:59 AM »
Sheared rivets on my '97 at about 70k. Had it all done while apart, too. Was pretty interesting keeping it woa'd up during Biketoberfest crowds as I recall.
F6BANGER
Albuquerque NM
« Reply #13 on: January 27, 2012, 07:58:50 AM »
forgot to mention, I definitely have a hard time putting it in neutral while the engine is running.
Michael K (Az.)
Glendale, AZ
« Reply #14 on: January 27, 2012, 08:02:21 AM »
EGGSACTLY!! Grin Pretty tricky ridin the beast for a few days before the dismantle!!
« Reply #15 on: January 27, 2012, 10:09:31 AM »
False.  Mobil 1 m/c oil has moly in it about 100ppm last time I checked and at one time was actually more than their 15w50 oil. if its over 500ppm then yes can be a problem, actually more so to the starter clutch.  usually only high oils will have 500-700ppm of moly, like torco, motul and redline. most others including diesel oils will be around 200ppm plus or minus 100
