August 21, 2025, 06:12:16 AM *
Author Topic: pinion cup clean out.  (Read 1052 times)
CASABROKER
« on: January 26, 2012, 12:45:33 PM »
ready to put drive shaft into pinion cup.  is it ok to blast the cup with brake cleaner to get it clean?  My concern is will I want to get the hole cleans in the pinion cup.
« Reply #1 on: January 26, 2012, 12:52:20 PM »
The holes go through to where the final drive fluid is.
I didn't feel bad about sticking the little red WD-40 tube in there to
give a little blast to make the holes clear, I might feel a little hinkey about
having break cleaner in there... ida know...
I got the cup clean, and blasted the holes as the last step I think...
Daniel Meyer
The State of confusion.
« Reply #2 on: January 26, 2012, 01:30:45 PM »
Wouldn't use brake cleaner unless the cup is off the final drive.
CUAgain,
Daniel Meyer
« Reply #3 on: January 26, 2012, 01:50:23 PM »
Try a good old fastion pipe cleaner.
Even a tooth pick. All you want to do is make sure they aren't plugged.
Sodbuster
« Reply #4 on: January 26, 2012, 04:41:46 PM »
compressed air works good
VRCC # 30938
