February 04, 2026, 03:32:16 AM *
Author Topic: Cam belt cover bolts  (Read 1802 times)
Romeo
J.A.B.O.A.
Romeo, Michigan
« on: January 28, 2012, 02:22:06 PM »
Can anyone tell me about the upper bolt on the right side looking from the front? I am trying to remove it and am having trouble. I seem to remember hearing something about sealant being applied to it because the threads reach into a cooling journal. Is that the case?  Can't seem to remove it with my standard Allen wrench. Do I just need to be more forceful, or is there some other problem?
slider
mulberry arkansas
« Reply #1 on: January 28, 2012, 02:49:26 PM »
I had the same problem,I used an allen head socket and short extension.....placed  the socket  inside the bolt  head  and gave  it a couple  of  sharp raps  and it turned loose and came out with a little effort,but it did break loose..mechanic at local dealer told me about this little trick..
a proud navy veteran
Romeo
J.A.B.O.A.
Romeo, Michigan
« Reply #2 on: January 28, 2012, 03:08:38 PM »
Thanks for the input Slider, I was able to remove it by adding a torque amplifier (small piece of pipe) to my allen wrench.
longrider
Vernon, B.C. Canada
« Reply #3 on: January 28, 2012, 03:28:00 PM »
Seems to help if the motor is at operating temp........  softens the sealant a bit
Romeo
J.A.B.O.A.
Romeo, Michigan
« Reply #4 on: January 28, 2012, 08:24:29 PM »
Where do I get the sealant to replace the bolt?
« Reply #5 on: January 29, 2012, 07:30:38 AM »
Sealant: I used a standard waterpump gasket sealant. It's a version of RTV I believe.
« Reply #6 on: January 29, 2012, 05:32:32 PM »
I use bathtube sealant. Come off easily with a little rubbing. Used it all the time when I used to overhaul VW engines.
sugerbear
wentzville mo
« Reply #7 on: January 29, 2012, 05:42:31 PM »
do yourself a favor and buy a good set of allen sockets.
didn't realize how much help they were until i bought mine. cooldude
