February 04, 2026, 03:32:07 AM *
Author Topic: Question on Rebuilding Petcock  (Read 1552 times)
vic
East TN
« on: January 30, 2012, 01:31:52 PM »
I changed the vacuum hoses on my '98 Tourer today and decided to rebuild the petcock since I've been having some instances that seemed like fuel starvation.  Took apart the petcock and found a couple of tiny tears in the old diaphram.  Got it back together and remembered reading here that you have to test the petcock by drawing a vacuum on it to make sure it works.  So I attached a vacuum hose to the petcock and tried to draw a vacuum by mouth.  A few drops of fuel slowly dribbled out after a few tries.
My question is, how much fuel is supposed to come out when you're sucking on the vacuum hose till almost blue in the face?  Is a few drops good, or is it supposed to stream out?  Thanks for any answers.
« Reply #1 on: January 30, 2012, 01:41:05 PM »
The gasoline should stream out.
Might be it's back together incorrectly but I would check to be sure you have gas in the tank first.
vic
East TN
« Reply #2 on: January 30, 2012, 01:48:11 PM »
I've got about 2 gallons of gas in the tank.  The tank is an I/S tank that I installed on my Tourer a few years ago.  I've got a diagram of the sequence of the petcock parts and took it apart and put it back together  a few times just to make sure its in the right order.  If fuel is supposed to stream out, then I guess its back to the drawing board!
Bone
« Reply #3 on: January 30, 2012, 01:55:20 PM »
Did you turn the petcock lever to the on position ?
vic
East TN
« Reply #4 on: January 30, 2012, 02:10:18 PM »
I turned the petcock to On and to Reserve and got a few drops each time.
N8171S
Marlboro, Mass
« Reply #5 on: January 30, 2012, 04:04:10 PM »
I made an aluminum plate and gasket and converted  both my valks to manual valves with Dan Marc electric shutoffs.  No vacuum lines.  Remember with a bad diaphragm fuel can leak into # 6 carb and cause a possible hydro.
Blackduck
West Australia
« Reply #6 on: January 30, 2012, 04:16:23 PM »
For fuel to reach #6 cylinder via the vacuum hose you need 3 faults,
2 torn diaphragms and a plugged weep hole as well as the petcock being in the on or reserve position. Not impossible but very unlikely.
MP
North Dakota
« Reply #7 on: January 30, 2012, 04:25:46 PM »
I have done that, draw a vac by mouth.  You should get a nice stream.
MP
"Ridin' with Cycho"
BonS
Blue Springs, MO
« Reply #8 on: January 31, 2012, 03:11:19 PM »
This thread is about modifying the petcock but has some great diagrams and photos that may help:
http://www.valkyrieforum.com/bbs/index.php/topic,37577.0.html
