November 23, 2025, 06:43:11 PM *
Author Topic: 99 Interstate No Fire  (Read 1299 times)
stevehi
« on: February 02, 2012, 09:28:03 PM »
First of all, want to say hi and thanks up front for any assistance provided.  I'm a newbie to the Valkyrie's and really excited about owning one, if I can ever get it to start.  My XR650L has decided that's what it wants to be when it grows up.
So here's how the story goes.  I acquired a 99 Interstate with about 34K miles on it.  I know the bike was in good running condition about a month before I ended up with it but it had gone through a couple people during that month.  When I got the bike, it had some teeth knocked off the starter & starter idler gears.  I tore the bike down and replaced those with out much trouble given I've never ventured that far into an engine that size before.  When I did my first test everything went perfect.  Bike turned over perfectly and I was ready to start riding by the weekend.  Then something happened, bike wouldn't turn over any more.  After trouble shooting I bought a starter relay and that did the trick.  Then during reassembly of all the wiring, I got a couple of them in the wrong places and when the battery was hooked up it blew the 50AMP fuse.  I went ahead and rewired it for a standard fuse of equal capacity and tried to start it.  It turned over like it should but never even tried to start.  So back to troubleshooting where I discovered I was getting no fire on all plugs.  Since that time I have double checked all the connection, fuses, etc.  I have also done a bypass on the bank angle sensor per some posts I have read.  Also checked the black/white wire at the coil pack that it's getting voltage when the switch is turned on.  I called the local dealer and asked about getting a replacement CDI, I woke up in the living floor with the phone in my hand and called back to clarified that I just needed the ignition module, not an entire new bike and pit crew to go with it.  I then asked if there was a way to test it and was told to check the resistance on it whit a meter but that's all he knew.  Couldn't give me any more info on which pins should have continuity, the resistance, etc and that's where I am.
Any suggestions on what to do before I eBay one of these things and it end up not being what I need.
Once again, thanks for your help.
Mr.BubblesVRCCDS0008
« Reply #1 on: February 03, 2012, 12:04:59 AM »
 Make sure the battery is charged to max before trying to start the bike.  You can try hooking it up to a non running car battery and I bet it'll start. These things have to get at lease ten volts to the coils to fire off. They will turn over like a sewing machine but will not fire. Also you could try to push start it. They crank very easy when pushed I have pushed started mine several times because of an alt. problem. Welcome to the club, your life has taken a turn to the good side.
olddog1946
Moses Lake, Wa
« Reply #2 on: February 03, 2012, 05:47:08 AM »
 cooldude cooldude cooldude +1 on a fully charged battery
 OH, and one more thing make sure the choke is actually working..it pulls to a point you think it is on but all you've done is take out the slack in the cable, it'll go another 3/8 " or so..
« Last Edit: February 03, 2012, 05:49:58 AM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Daniel Meyer
The State of confusion.
« Reply #3 on: February 03, 2012, 08:35:11 AM »
Also be aware that the original issue...broken teeth on the starter gears, was probably hydrolock (gas in the cylinders) and you need to check/repair the petcock and probably clean the carbs...
CUAgain,
Daniel Meyer
stevehi
« Reply #4 on: February 03, 2012, 09:04:58 PM »
Pretty sure the battery is good but will do the car battery check just to be sure.
As for the Hydrolock comment, thanks for that info because I was wondering what would cause that.  It's a relatively cheap fix, under 100$, but the time involved in tearing it down and putting it back together is a different story.
I will double check all the suggesting and let you know.
« Reply #5 on: February 04, 2012, 05:13:17 AM »
While your at it, a new set of plugs may help!  Roll Eyes
My rides:
« Reply #6 on: February 04, 2012, 09:17:02 AM »
Only and if the boss located within the motor has not been broken off. 50/50 chance from what's been posted on the forum past years.
