March 28, 2026, 11:32:23 PM *
Author Topic: right side rear wheel bearing  (Read 846 times)
robin
Get on it and RIDE!!
Hardwick NJ
« on: February 04, 2012, 09:35:59 AM »
I did post it on the tech board also not much response so i'll ask over here also took my rear wheel off for some maintenance and found that i could pull the right side wheel bearing out with my fingers what do ya think?
The wheel is chromed don't know if maybe there was chrome in there and has worn away leaving it loose?
Will a new bearing fit better?
      HELP
Highbinder
Bastian/Tazewell,VA.
« Reply #1 on: February 04, 2012, 09:43:44 AM »
Robin, you don't want that race spinning in the hup, it will ruin the wheel....try a new bearing and if it fits tight all is good...if not try burring the inside of the hup to make it fit tight, I've done this a few times and solved the problem...and yes sometimes they do get the chrome on the inside, but usually this will stop the bearing from going in....I hope it works out well for ya... cooldude
« Reply #2 on: February 04, 2012, 03:51:52 PM »
You can also take a feeler gauge break off the correct thickness and put it in about 1/2 way then tap in the bearing. May take more than one try.
BigAl
« Reply #3 on: February 04, 2012, 04:12:53 PM »
Another old Machinist Trick is to take a center punch, a pointed one, then with hammer in hand, dimple it evenly
by striking the punck with even blows.
This will raise up some metal to grab that outside diameter and make it fit tight.
Also a gun trick is to use lock tight once you get it fitting better.
This will lock it in place and you will still be able to remove it later with regular tools.
It worked for Lucky 13 and I only dimpled it in 4 places evenly spaced inside the place that the bearing usually resides
in the wheel.
You need more, try eight spots at first, dimpled to raise the metal and check for fit.
The aluminum wheel is soft so don't go crazy on hte dimpling.
It will work.
« Last Edit: February 04, 2012, 04:15:49 PM by BigAl » Logged
BigAl
« Reply #4 on: February 04, 2012, 04:16:59 PM »
Or buy  a used wheel.
robin
Hardwick NJ
« Reply #5 on: February 04, 2012, 04:39:07 PM »
I spoke to JP today and asked him about the wheel and he suggested finding a machinist and cut the wheel and fit it with brass sleeve.
Well it just so happens that my lovely wife works with a girl who's husband has a shop not to far from my work so i called him about it and he said no problem as he told me they do aerospace work and that would be a simple thing for them to do.I love it when i get lucky sometimes cooldude
 Thanks for all your replies good info to tuck away in the old memory banks
Warlock
Magnolia, Ms
« Reply #6 on: February 04, 2012, 06:41:01 PM »
      HELP
I posted you something on the tech board. Had the same thing happened to my chrome rim. Posted a fix for it.
David
