SpidyJ
« on: February 06, 2012, 04:00:00 AM » |
Which model # should I buy? Do I need any adapters or will it screw right into the tank? I want a vacuum type.
thx
1999 Fast Black Interstate
Peace, johnnywebb
JC
The Beast
Franklin, TN
« Reply #1 on: February 06, 2012, 05:37:39 AM » |
I think its a 1311CHV that you're looking for.
SpidyJ
« Reply #2 on: February 06, 2012, 08:04:37 AM » |
Does the pingel bolt right up to the IS tank or do I need some sort of adapter?
I'm hesitant to lay out the dough until I know.
Peace, johnnywebb
« Reply #3 on: February 06, 2012, 08:52:48 AM » |
Yep, it'll go right in the same way as the old petcock.
You will not be able to keep the chrome knob however, the old one associated with the stock petcock.
« Reply #4 on: February 06, 2012, 08:58:35 AM » |
It threads on to the same threads as your oem petcock. Be aware that it has half a gallon reserve capacity as opposed to the full gallon of the oem petcock. If the filter screen stays, inside the tank, fine. If not you may be able to reinsert it. If You can't, you will have to buy a new one. Not a bad idea anyway. Hoser
SpidyJ
« Reply #5 on: February 06, 2012, 10:04:50 AM » |
Doesn't the Pingel come with a filter screen?
Peace, johnnywebb
« Reply #6 on: February 06, 2012, 12:38:25 PM » |
« Reply #7 on: February 06, 2012, 02:22:22 PM » |
My pingel came with a stainless steal filter screen. The pingel will be a hair small to hook up to you fuel line. A good hose clamp will help. I added a additional fuel filler between the pingel and oem fuel line.
offroadchevy806
« Reply #8 on: February 06, 2012, 02:50:37 PM » |
what kind of fuel filter did you use?
« Reply #9 on: February 06, 2012, 03:02:44 PM » |
Guess I got shorted, I used the one from the oem. It worked fine, though.  Hoser
« Reply #11 on: February 06, 2012, 03:17:07 PM » |
It would be handy to have detents, I will certainly check that out if I get another. Hoser
« Reply #12 on: February 06, 2012, 04:14:39 PM » |
what kind of fuel filter did you use? A small little silver one from Auto Zone. It was a Fram filter. I change it every year.
« Reply #13 on: February 06, 2012, 04:15:35 PM » |
Guess I got shorted, I used the one from the oem. It worked fine, though.  Hoser I've been shorted in other ways.
« Reply #14 on: February 07, 2012, 04:06:55 AM » |
I feel your pain Fudgie, my 5'9' looks short when I run around with MP. Hoser
Momz
« Reply #15 on: February 10, 2012, 06:35:54 AM » |
The Pingel doen't have detents?
 ALWAYS QUESTION AUTHORITY! 97 Valk bobber, 98 Valk Rat Rod, 2K SuperValk, plus several other classic bikes
« Reply #16 on: February 10, 2012, 06:51:28 AM » |
That's correct! Turned all the way in one direction, the stopcock is "off", turned the opposite direction all the way and the stopcock is "on". About 180 degrees (or less) in travel. "reserve" is midway between the two. Very simple and easy to understand and operate. No detent needed! ***
