January 28, 2026, 03:25:23 PM *
Author Topic: I/S Trunk Lights - Various Wiring Patterns  (Read 2606 times)
bassman
« on: May 12, 2009, 07:58:43 AM »
Does anyone have or recall seeing a link describing various ways/mods to wire I/S trunk lights i.e., outer lights turn signals, inner lights running; both left lights turn signals and both right lights turn signals; believe there were some flashing lights option and a couple of others as well......I remember seeing something about this but for the life of me can't remember the details or locate the link again. Undecided
TIA !
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: May 12, 2009, 08:16:15 AM »
I added a pair of additional LED (amber) lights, for use as extra, high mounted turn signals.  They work great at night, but I'm looking for something a bit more visable in the day time.
I also added a SOMA (stay off my ass) module, from Signal Dynamics, inside the trunk, that either rapidly flashes, or 'wig-wags' the brake lights. I also have one in the rear fender light.
http://www.signaldynamics.com/lighting_control.htm
Really gets the attention of cagers.  I actually had someone pull up along side of me and say "Did you know your brake lights flash when you stop?"
Black Dog
Don't you know...
Kingbee
VRCC# 576
Northern Illinois
« Reply #2 on: May 12, 2009, 08:21:24 AM »
http://www.horseapple.com/Valkyrie/Tech_Tips/IS_Trunk_Signals/is_trunk_signals.html
1999 Interstate
2000 Interstate
2004 Rune
bassman
« Reply #3 on: May 12, 2009, 02:06:46 PM »
Thanks guys !    I think I finally found what I was originally looking for on Chet's site (where else!!)
http://www.rattlebars.com/mtz/istrunklights.html
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: May 12, 2009, 02:22:35 PM »
Neal, remember that when putting an I/S trunk on a STD or Tourer you may want to check your fuses. If you're going to be permanently mounting that trunk; use the fuse amp values for an I/S. If you remove the trunk, you're still "good to go".
Ride happy
ALWAYS QUESTION AUTHORITY!
bassman
« Reply #5 on: May 12, 2009, 05:38:57 PM »
Thanks Momz - good info....
