January 28, 2026, 03:25:22 PM
Replacing Clutch
Topic: Replacing Clutch (Read 2574 times)
Wags
Replacing Clutch
May 12, 2009, 09:03:43 AM »
I'm about to jump into replacing my clutch on a 1999 Interstate with 80,000 + miles. I have reviewed the archive posts but have a few questions yet.
It is typical to have to replace the clutch basket?
Local Honda dealer quoted me $370 for a Honda kit that includes metal & fiber plates, gasket, and spring. Is this a bit high?
Is there a Barnett kit that has metal & fiber plates, gasket, and spring?
As long as I'm in there should I replace anything else?
I think I have enough stuff laying around that I can fabricate a spring compressor and other special tools.
Wags
Madmike
Campbell River BC, Canada
Re: Replacing Clutch
May 12, 2009, 09:10:13 AM »
.......................there are a couple of toll free numbers at the top of this page, they will most likely be happy to answer your questions............
http://www.hdlparts.com/fiche_section_detail.asp?section=148511&category=Motorcycles&make=Honda&year=1999&fveh=3473
Jeff K
May 12, 2009, 01:53:18 PM »
Unless you had a catastrophic clutch failure there should be no reason to replace the basket, I always use OEM cluch parts.
