February 04, 2026, 03:24:43 AM *
Author Topic: Audiovox UltraCruise II Cruise Control  (Read 2204 times)
bscrive
Ottawa, Ontario
« on: February 12, 2012, 01:19:55 PM »
Has anyone tried to install this cruise control on your IS.  I don't think it would work for a standard or a tourer model.  Would it be any better than the CCS-100 model.  I have the CCS-100 model right now but it has been in for 8 years and you never know when it could quit.
Here is the link.  http://www.audiovideo4me.com/Audiovox_250_1316_Ultracrusie_II_Cruise_Control_p/250-1316.htm
Any comments.
« Reply #1 on: February 12, 2012, 01:25:43 PM »
Any comments.
Mine from Australia has been on MGM since January 98, no problems and it still maintains + or - 3 mph on hils flat curves whereever I'm at and have it set at.
If it still works, leave the damn thing along, all you will do is muck it up.  Don't ask how I know.    Just say 79 years of experience.
Firefighter
Harlingen, Texas
« Reply #2 on: February 12, 2012, 05:10:44 PM »
I am interested in installing a cruise control on my 2000 IS. Does this system need an extra speed sensor or does it use the IS electronic speed sensor?  I dont really wont to bolt a extra sensor to the wheels. Thanks
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
NITRO
Eau Claire, WI
« Reply #3 on: February 12, 2012, 07:01:58 PM »
If it works the same as the model everybody else has used in the past, it picks up engine speed from the coils, you just have to solder into them.
When in doubt, ride.
jer0177
VRCC 32975
Pittsburgh, PA
« Reply #4 on: February 12, 2012, 07:47:50 PM »
The IS uses a VSS to control the electronic speedo instead of a cable model like the Standard/Tourer use.
olddog1946
Moses Lake, Wa
« Reply #5 on: February 12, 2012, 10:25:24 PM »
According to the info it comes with a VSS sensor, so there is no reason it couldn't be used in any Valk. When I get ready to install one on mine, this will be what I use, with the magnet mounted in the rear wheel with the wiring set up under/along the swing arm.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
alph
Eau Claire, WI.
« Reply #6 on: February 13, 2012, 04:08:35 AM »
don't know about it, i've got the one that uses vacuum, pulled the vac off of cylinders 1 & 2 without a canister, works fine.  i would say that it was the best "item" i instaled on my cycle. i use it everytime i ride.
