May 02, 2026, 04:42:12 AM *
Author Topic: Side Covers  (Read 2046 times)
WDAN
Irving, TX
« on: February 13, 2012, 12:00:39 PM »
What is the trick to removing these without breaking the tab/tabs???
I removed the left one today (for the second time) and broke the last tab. I probably broke the first tab first time.
I was going to have them chromed. Now, I am wondering what to do.
Try to use the one I broke or try to find a good one.
As easy as they are to break, is it worth spending $250 to have them chromed? (assuming I can get the other two off without breaking tabs.
WDAN
Irving, TX
mario
NW Houston, TX
« Reply #1 on: February 13, 2012, 12:53:56 PM »
i'm assuming you broke the tab that faces the front of the bike??
i was told you work from back to front, popping out the gromets one at a time and then carefully work out the tab at the front.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
WDAN
Irving, TX
« Reply #2 on: February 13, 2012, 01:53:18 PM »
That's where I went wrong.
WDAN
Irving, TX
Timbo
Carrollton, TX
« Reply #3 on: February 14, 2012, 04:03:26 AM »
When I bought my Valk, one of the side covers was taped on.  I found an article on the board (I will have to search for it later) that shows how to use a paperclip (or similar metal object) and super-glue it inside the cover so it pops right on.  I'm off to work, but will either find the article or post pictures of my repair when I get home.  The fix is easy enough for even me, and it works like a charm!
Of course, there is always velcro....which is even more simple.
Timbo
Carrollton, TX
« Reply #4 on: February 14, 2012, 04:18:40 AM »
Found the article...followed the instruction for the RadDog Paperclip trick (midway down)
http://www.valkyrieforum.com/bbs/index.php/topic,3963.0.html
« Reply #5 on: February 14, 2012, 07:01:41 AM »
I have a similar problem with my right cover, but the tab broke off of the Center section...   tickedoff
Been using the velcro method for 3 years now and no problems.
Hay  Cool
« Reply #6 on: February 14, 2012, 07:17:13 AM »
When I got my Valkyrie, I heard so much about busted tabs and $150 plastic
side covers that I got very paranoid.
There's two versions of "the trick"...
1. Read the step-by-step procedure in the owner's manual, remember it forever,
    and follow it.
2. Read the step-by-step procedure in the owner's manual, follow it, and
    then promptly forget the details, but don't worry, the owner's manual
    is under the seat  cooldude
I use number two, so I don't remember the details, but the owner's manual
indicates which tab to pull first, and where they all are. When I'm at home,
I put a tiny squirt of WD40 on the rubber grommets right before I pop it
back together...
WDAN
Irving, TX
« Reply #7 on: February 14, 2012, 01:51:27 PM »
Thanks for all of the information regarding repairing these side covers.
Since I am planning on having them chromed, I went ahead and plunked down the cash for a new one. That hurt but I don't want to spend the big bucks for chroming on a cover that I have tried to repair!
Honda must have sold thousands of these covers in aftermarket. You can't tell me they did not know what they were doing.
WDAN
Irving, TX
