February 04, 2026, 05:21:23 AM
Exhaust pipe removal
Topic: Exhaust pipe removal (Read 1334 times)
cajunito
San Antonio,Texas
February 15, 2012, 02:33:56 PM »
I am still trying to install my champion bags,which has turned into quite an ordeal. Come to find ou,I have to drill holes in the bottom of the bags to attach the support.. seems this can't be done without taking the exhaust pipes off,and I am having a hell of a time with it. Any simple way to do this that I am missing? Thanks!
CASABROKER
Re: Exhaust pipe removal
February 15, 2012, 04:00:30 PM »
Gotta take off engine guards, brake pedal. Also put new exhaust gaskets on very advisable. Do not over torgue exhaust nut 7 lbs torque bust one and you'll have a bad day.
Challenger
February 15, 2012, 04:30:24 PM »
I might have done mine wrong, but I did not have to remove the exhaust, I installed the brackets, set the bag on a the mufflers with a 3/4" styrofoam spacer, marked bags on the back side, set bags on floor, drilled holes, installed on bike
cajunito
San Antonio,Texas
February 15, 2012, 04:38:01 PM »
Thanks Challenger... something I certainly didn't think about.. I already have the bags made up,but I will take them off & try that approach.
