February 04, 2026, 05:20:50 AM *
Author Topic: Valk Diff / Gl1500 same???  (Read 1642 times)
Donald
Edmonton AB Canada
« on: February 15, 2012, 07:10:27 PM »
I cant find the part numbers through my Honda books, does anyone know if the Valk diff (03 Standard) is the same as a 97 Goldwing (Gl1500).  I have an opportunity to pick up a free one and if it is the same as my Valk, I will take the trip to pick it up.
Look forward to your comments.
If you can't have fun???Why be here???
keepinon
New Caney, Tx
« Reply #1 on: February 15, 2012, 07:15:27 PM »
Short answer, no.
The 'wing diff has a different drive shaft bolt pattern.
1998 GL1500 CT Trike
Donald
Edmonton AB Canada
« Reply #2 on: February 15, 2012, 11:52:18 PM »
   Well Thank you, just saved a 300 mile round trip and a disappointment.
« Reply #3 on: February 16, 2012, 05:37:01 PM »
I believe others have posted that the internal gears are the same.
If not, I wonder if you could put the gears (fit) inside a Valk from a GW, and what the rear ratio might change to.
« Last Edit: February 17, 2012, 07:11:27 PM by gordonv » Logged
keepinon
New Caney, Tx
« Reply #4 on: February 16, 2012, 06:51:05 PM »
If not, I wonder if you could put the gears (fit) inside a Valk from a GW, and what the hear ratio might change to.
Nah, I tried it last summer on a friends bike. The ring gear & pinion has different numbers for a 'Wing than a Valk. Tried like hell to make 'em fit...  ended up getting another Valk final drive.
lucky_1_chris
Arlington, TX
« Reply #5 on: February 17, 2012, 12:33:54 PM »
I would get it if it's in good shape. The gear sets are the same.
1999 Valkyrie Interstate
« Reply #6 on: February 17, 2012, 03:38:20 PM »
same ratio
