February 04, 2026, 05:19:28 AM *
Author Topic: Front wheel bearings  (Read 1648 times)
YoungPUP
Valparaiso, In
« on: February 17, 2012, 05:06:23 PM »
SO while getting my front tire replaced, I noticed that the bearings have a flat spot in them. While trying to remove them, I've broken 3 bearing pullers.  2 press type, and one slide hammer style. I've tried using a punch through the wheel, but with the tube that runs between them I cant get a bite on the back of them.  Any ideas before I let the dealer soak me for $100 for an hour of labor?
99 STD (Under construction)
wiggydotcom
Yorkville, Illinois
« Reply #1 on: February 17, 2012, 05:46:20 PM »
Someone else willl chime in, but I'm thinking they can still be punched out, even with the spacer in.
It's been a few yrs since my fronts were done, but I had the same issue with pullers..it seemed that the spacer would just move to the side enough to catch the inner race with the punch.
VRCC #10177
VRCCDS #239
« Reply #2 on: February 17, 2012, 05:52:03 PM »
Try warming them up with a torch. Freeze the new ones so they slip right in.
YoungPUP
Valparaiso, In
« Reply #3 on: February 17, 2012, 05:57:58 PM »
New ones already in the freezer, maybe a bigger hammer???
tank_post142
south florida
« Reply #4 on: February 17, 2012, 06:39:52 PM »
i used a straight rod rather than a punch and sharpened the edge to a crisp 90 degree angle.
I got a rock Sad
VRCCDS0246
« Reply #5 on: February 18, 2012, 08:15:10 AM »
Yep, this would be the way!
YoungPUP
Valparaiso, In
« Reply #6 on: February 18, 2012, 09:33:39 AM »
Thanks to those that posted. Got them out thismorning with a piece of heavy wall round tube,( leftover from making new shock bushing sleeves) and a bigger hammer.
