February 04, 2026, 05:22:04 AM *
Pages: 1 [2]   Go Down
Author Topic: overheating!!!  (Read 3983 times)
F6BANGER
Albuquerque NM
« Reply #40 on: February 19, 2012, 09:23:42 PM »
offroadchevy806,
Where do you live? Maybe someone that lives by you can trade radiators for a few hours. See if a different one does the trick. I looked up where you live on your profile and cant find it. If you are near me, I will let you use mine.
offroadchevy806
Lubbock, TX
« Reply #41 on: February 19, 2012, 09:28:38 PM »
I live in Lubbock,TX
F6BANGER
Albuquerque NM
« Reply #42 on: February 19, 2012, 09:40:23 PM »
Maybe one of them will step up and give you a hand. cooldude
http://members.vrccservices.com/membership/field-search-results.php3?active=Y&club_num=0001&club_id=&state=TX&city=lubbock&handle=&first_name=
Good Luck
I only saw two people from Lubbock in  Vortex.
http://www.f6rider.com/Valk/vortex.htm
« Last Edit: February 19, 2012, 09:49:02 PM by F6BANGER » Logged
offroadchevy806
Lubbock, TX
« Reply #43 on: February 19, 2012, 09:44:04 PM »
thanks, i am about to message all of them lol, i am getting desperate
Earl in Pensacola
« Reply #44 on: February 20, 2012, 06:57:11 AM »
I have the '97 OEM radiator with 248K on it and if I were to let mine idle for 20 minutes, with or without the fan on, it would het to the 240 range and might even boil over.  Yet cruising down the hywy my gauge reads 180f to 190f depending on outside temp and how fast I'm moving!  As long as your temp. will return to the "normal" range within a couple of miles with a steady rpm of about 2k or more, you likely don't really have a radiator problem.  If your fan will come on at about 212 degrees, it's doing it's job.  It can not keep your engine from eventually reaching the over-heated range at idle.   JMHO
offroadchevy806
Lubbock, TX
« Reply #45 on: February 20, 2012, 01:01:06 PM »
the fan is not coming on at all, i replaced the thermo fan switch, and started to fell the radiator and down by the fan switch is alot cooler than the right side of the radiator
Pages: 1 [2]   Go Up
