February 04, 2026, 05:15:33 AM *
Author Topic: Swing arm cover installation  (Read 1468 times)
rxvalk
Nebraska
« on: February 21, 2012, 06:38:05 PM »
I purchased a set of chrome swing arm covers. What is the best double sided tape to use. Any hints or pointers to ensure a problem free installation?
The best therapy is a long ride on my valk
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: February 21, 2012, 10:06:49 PM »
rxvalk....I take it that you bought a used set seeing that new they came with the two faced already on the back.  I try to use a good brand of tape when I do use it.....My choice is the 3-M brand.
BigBod
Sunny West Sussex, England.
« Reply #2 on: February 22, 2012, 01:00:43 AM »
I bought mine brand new and they wern't a perfect fit. I clamped them in place overnight and they haven't budged since.
If you have a used set, have you considered using epoxy instead of tape? A 2 part long cure would be the best, golf club epoxy would be strong enough. If you needed to remove them at a later date for any reason then a heat gun would break down the epoxy.
rxvalk
Nebraska
« Reply #3 on: February 22, 2012, 01:51:11 PM »
Thanks guys did not think to add they were used.
wdvalk
Katy Texas
« Reply #4 on: February 22, 2012, 05:28:23 PM »
i would like to see a pic of these covers
« Reply #5 on: February 22, 2012, 05:43:59 PM »
Don't know about epoxy, but I have added a bead or two of RTV clear silicone to various chromy/shiny parts where the double sided tape didn't look all that secure.... specifically on swingarm and drive shaft covers.  Holds well, insulates potential vibration, keeps out moisture, but can be pulled off any time with ease.
Obviously, everything need to be clean first.
F6Dave
3M
« Reply #6 on: February 22, 2012, 07:22:23 PM »
3M has a very good heavy duty tape designed for outdoor use.  It is dark red in color.  I used it when the original tape on my swing arm covers worked loose, and it has been sticking fine for several years.
