February 04, 2026, 05:09:20 AM
truck stacks
Topic: truck stacks (Read 1799 times)
v-man1
truck stacks
February 22, 2012, 04:58:58 PM »
Hello.Just purchased truck stacks to install on my stock exhaust.Already have cut the slot in them.When grinding the weld spots flat to allow the stacks to slide over the muffler,is it necessary to grind flat the welded seam that runs the length of the muffler?Also,what are some of the favored lubes to help get the stacks on? Thanks
Re: truck stacks
February 23, 2012, 05:16:20 AM »
You don't want any welds "proud" or sticking out from the surface of the can. I used WD40.
bscrive
Ottawa, Ontario
Re: truck stacks
February 23, 2012, 12:21:25 PM »
I didn't grind the seam, I used just plain soap to slip the stacks on. Took a little bit of force but not too bad. You can use WD-40 like Skinhead said or any thing else to provide lube. Just make sure that your pipes are cold and it would not hurt to warm up your stacks before you slip them on.
