February 04, 2026, 05:09:10 AM
Thermostat replacement
Topic: Thermostat replacement (Read 1321 times)
Steppenwolf
February 23, 2012, 06:47:01 AM »
Hey guys, is the thermostat housing at the end of the radiator house like a car or is it deeper into the block?
Re: Thermostat replacement
February 23, 2012, 06:57:44 AM »
It's located at the other end of the top radiator hose.
A bit of work to get at.
F6Dave
February 23, 2012, 07:12:30 AM »
It sits on top of the block like a car. I've read that there is an automotive equivalent part. All you need to remove is the radiator, with one bolt at the top. The tricky part is removing the 3 bolts holding the thermostat housing. There's very little clearance for one of them. I think I used a 1/4" socket set.
Steppenwolf
February 23, 2012, 09:14:09 AM »
Thanks for the info guys. Yeah, it all makes sense now. Prolly as easy to get at as replacing the alternator eh?
February 23, 2012, 11:39:07 AM »
Not something you'd normally do as a maintenance item.
The thermostats rarely go bad.
