February 04, 2026, 05:09:22 AM *
Author Topic: Bearing??  (Read 1304 times)
« on: February 23, 2012, 08:26:38 AM »
Hey Guys & Girls;
I'm down in Brooksville Fl visiting w/friends.  I trucked to Ga and rode down here 2 wks ago.  Been out to Key West and back enjoying the weather and roads (trafffic, not so much)
Anyways, the reason I'm in the tech board is, I'm getting a noise from the rear end, a very light "thum, thum, thum, at over 30mph.  Then when I hit the rear brake, it sounds like something is stuck in the pads until I get down under 30 or so.
Can't see anything in there, but haven't taken it apart yet.
I'm hoping it's not a rear bearing, they seemed fine when I had it apart this last Jan.
Does this sound like a bearing going?
Thanks;
Bill
« Reply #1 on: February 23, 2012, 09:12:22 AM »
This is what mine sounded like when my left rear wheel bearing went out.......
Brake caliper noise?powered by Aeva
Left rear wheel bearing noise?powered by Aeva
F6MoRider
Lakeland, FL
« Reply #2 on: February 23, 2012, 09:54:12 AM »
I'd be interested in knowing the mileage on the bearing when this "bearing" noise occurs.
Is there a clear and focused discussion available in ShopTalk on this bearing issue?  I searched but found many fragments of the discussion, including comments that say do it and others that say don't unless you have a failure.  A comprehensive list of steps and parts (with #'s and links to images) would be most helpful.
If there isn't one, maybe that's what we need.  I wouldn't be adverse to pulling it all together and having it reviewed by those who've done the mod if needed.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
« Reply #3 on: February 23, 2012, 11:35:20 AM »
Yeah,
especially doing it four times...........
Sounds like poor installation if you ask me.
The only way to tell if a bearing is bad is to get access to it and feel it with your finger.
Now I know there are other limitations and ways to test, but with a bearing in the wheel, this is about the only practical way.
