ryord
« on: February 24, 2012, 05:54:48 AM » |
Hello, I have babied, studied, rebuilt, prayed upon,asked for spiritual healing and stood there with my pants at half mast while singing the Japanese state anthem, nothing worked, ready to try a pingle or something better. Would like some input. Thanks in advance. Rick
Farther
« Reply #1 on: February 24, 2012, 08:13:25 AM » |
...singing the Japanese state anthem... There's your problem. The Valkyrie is an US made bike.
Thanks, ~Farther
bscrive
Ottawa, Ontario
« Reply #2 on: February 24, 2012, 09:00:04 AM » |
...singing the Japanese state anthem... There's your problem. The Valkyrie is an US made bike.  That's funny Farther. Ryord, just put in a Dan-Marc fuel shut off and your problems will be solved. You don't have to remember to shut anything off. Just do the modification of the oem petcock that Gryphon Rider suggested in an earlier thread and you are golden.
« Reply #3 on: February 24, 2012, 09:06:02 AM » |
I like the manual Pingle, just remember to use it.. It'll eventually become a habit.. Its still not a guarantee against a fuel-lock, but, it'll help.. Add a fuel filter while you're at it..
rmrc51
Palmyra, Virginia
« Reply #4 on: February 24, 2012, 10:00:17 AM » |
I was fed up with my OEM as well after trying to rebuild it twice with no luck. Being that I was going to replace it, I didn't take any changes so I put in a Dan-Marc fuel shut off along with a Pingel. Just an extra precaution against Hydro-Lock.
VRCC # 30041
RUDE DOG - Steelers
« Reply #5 on: February 24, 2012, 02:58:51 PM » |
You had me laughing there, good stuff. I installed a Golan with one of their Micron filters on my I/S. I went with the Golan because it has the detents. Pretty easy to get into the habit of turning off the petcock. I may add the Dan Marc shut off down the road as another precaution.
RonW
« Reply #6 on: February 24, 2012, 03:21:07 PM » |
buy yourself a brand new oem petcock. Even doorknobs and hinges wear after years of use from the motion of opening and closing.
2000 Valkyrie Tourer
Chattanooga Mark
« Reply #7 on: February 24, 2012, 06:25:44 PM » |
Can't you just turn the oem petcock on and off with the key and not have to worry about hydro lock?
A search using "Dan-Marc fuel shut off" returns no results using the search function. So, what's a Dan-Marc fuel shut off?
Mark
« Last Edit: February 24, 2012, 06:29:10 PM by Chicago Mark »
...do justice, love kindness, walk humbly... The Bible: Read, Apply, Repeat 2012 Victory Cross Country Tour, in all its pearl white beauty www.bikersforchrist.org
ryord
« Reply #8 on: February 24, 2012, 07:35:36 PM » |
Thanks for the responses. The OEM petcock is new as of last year, I did have an inline filter which I removed. It still seems to just occasionally run out of gas when I am about 3 gallons down. Recovers when I put it on reserve. I should still have about a gallon or more before it hits the true reserve point. Venting is no problem checked that. Seems to happen when the weather gets a little warmer about 55 degrees and at highway speeds. It is the only issue that I have with my 2001 Standard with about 12k miles on it. Rick
« Reply #9 on: February 25, 2012, 05:37:27 AM » |
Rebuild it, or replace it, but don't leave it that way till it sneaks up on you. Pingel, oem, or golan. Hoser
ryord
« Reply #10 on: February 25, 2012, 06:31:24 AM » |
OK, So I choose between a pingle and golan. They both look good. The golan web site states they have a model with an extra long feed tube. what are you thoughts on that. I am not sure I want to try to extend the tube on the pingle or even if it is necessary. Let me know what you folks think. Rick where we will have a nice warm day in Kansas City area.
Mr.BubblesVRCCDS0008
« Reply #11 on: February 25, 2012, 07:07:48 AM » |
You could just convert the OEM petcock to a manual valve. I've been manual for at least three years with no problems.
Bone
« Reply #12 on: February 25, 2012, 07:11:08 AM » |
I converted my OEM to manual after the diaphragm got a tear. That allowed the gas to follow the vacuum line to the engine. The diaphragm is gone.
Bone
« Reply #13 on: February 25, 2012, 08:26:24 AM » |
Turning off the valve manually is not for everyone. I've done it my entire riding span continuing with bikes that didn't require shutoff. To many it's a great convenience for $100.
« Reply #14 on: February 25, 2012, 08:40:46 AM » |
Mark
For those who have been offline to the problem and the Dan-Marc solution - my tech page explains the need and the DM solution: http://www.horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
PharmBoy
« Reply #15 on: February 25, 2012, 11:47:13 AM » |
ryord, If you decide to trash your OEM petcock and go with something else send me a PM. I would probably be interested in your OEM petcock...Jim
A politician is a fellow who will lay down your life for his country. ~Texas Guinan 4th Infantry Tet Vet 99 Interstate 97 Bumble Bee 97 Red & White
whitestroke
« Reply #16 on: February 26, 2012, 11:12:01 AM » |
Is there a way to fit a fuel filter in there with the Dan-Marc?
Minibike Honda S90 Yamaha YL100 Bultaco 250 Matador Bultaco 250 Pursang Yamaha 250 YZ Triumph 650 Bonni Honda ATC 200
2 Kids 25 year break. Suzuki GS 500 2003 VTX 1300S, 1998 Valk standard 2008 Goldwing
John U.
« Reply #17 on: February 26, 2012, 05:46:45 PM » |
Golan makes two types of filters. They both filter down to 10 microns (I think) but one is much smaller in length. You might get that one to fit upstream of the Danmarc.
cajundood
« Reply #19 on: February 27, 2012, 02:53:00 PM » |
...singing the Japanese state anthem... There's your problem. The Valkyrie is an US made bike.  amen brother
LIFE's BETTER ON THE DARKSIDE
Chattanooga Mark
« Reply #20 on: February 27, 2012, 07:20:16 PM » |
MarkT,
Great write up! Thank you for the link.
Mark
