February 04, 2026, 08:45:52 AM *
Author Topic: Clutch question  (Read 1438 times)
grandpaweaver
Barberton, Ohio
« on: March 01, 2012, 04:37:17 AM »
Pulled the bike out the other day after it has been sitting in the garage for about 2 weeks. When I hit the starter button in lunged forward. I had the clutch fully engaged. Tapped it a couple more times and each time it wanted to jump forward again until it started then it was ok. Rode to work with no problems. Could this be a problem with the clutch? I'm knew to this so would be thankful for any advice.
Isaiah 41:10
junior
new hampshire
« Reply #1 on: March 01, 2012, 04:46:42 AM »
its a wet clutch, and you prob had a couple of plate stuck together and the broke free. its semi common. mine does it every spring
« Reply #2 on: March 01, 2012, 05:16:25 AM »
The best advice for you would be to only start the bike in neutral, especially when first off.
Starting the bike in gear is, well, you get the idea!
DFragn
« Reply #3 on: March 01, 2012, 08:24:16 AM »
Maybe I'm a moron, but I don't buy that statement completely.
junior
new hampshire
« Reply #4 on: March 01, 2012, 11:23:05 AM »
how can i exsplaine this to you? its a wet clutch, if you dont atleast crank it over once or twice a month the half of the clutch tends to dry out and stick to the spring plates..............
« Reply #5 on: March 01, 2012, 11:25:49 AM »
A clutch hanging up ?? It doesn't matter whether its wet or dry, it happens..
YoungPUP
Valparaiso, In
« Reply #6 on: March 01, 2012, 04:51:34 PM »
My '99 does it too, esp. after sitting for Long(weeks+) periods of time.
99 STD (Under construction)
Sonny
Holt, Mo.
« Reply #7 on: March 01, 2012, 06:57:15 PM »
If it doesn't rattle and doesn't slip it's fine.
Good rule to follow is never start your bike while in gear.
Kind of like never pull right up next to the car in front of you at a stop light.
Always leave enough room to go around. Always be safe!
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
grandpaweaver
Barberton, Ohio
« Reply #8 on: March 02, 2012, 04:30:54 AM »
Thanks guys, skierd the crap out of me when it jumped about 3 feet. Start in N from now on.
Isaiah 41:10
