November 23, 2025, 09:05:48 PM *
Author Topic: Ca. Desmog have you done one? Need clarification.  (Read 1171 times)
whitestroke
San Pedro, Ca.
« on: March 05, 2012, 11:09:20 AM »
Two questions each with its own picture...
These 2 lines (only one side in pic) Originate between carb 3&5 and 4&6 go to Carb Air Vent Valve.  Do they need to be left open (disconnected) with a filter on them?
In case your wondering, Cylinder #3 is now working at idle. Just puttin things back together and will post details on original thread, after I go for a test ride.  Grin
This 6 into 1 that goes to Evap Purge Control Valve, just needs to be capped either at all 6 carbs or the way you see it in pic.  Is this correct???
« Last Edit: March 05, 2012, 11:16:57 AM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
SCain
Rio Rancho, NM
« Reply #1 on: March 05, 2012, 11:35:34 AM »
These 2 lines (only one side in pic) Originate between carb 3&5 and 4&6 go to Carb Air Vent Valve.  Do they need to be left open (disconnected) with a filter on them? These need to stay open, on the 49 State Carbs the hoses go to the rear carb support and the hoses have a turn down which goes into the two holes on that support. On mine, I used one of the left over "T's" and put one of those air breather filters.
This 6 into 1 that goes to Evap Purge Control Valve, just needs to be capped either at all 6 carbs or the way you see it in pic.  Is this correct??? Yes, get rid of the hoses and put some caps on the carbs, this way you don't have to do it later when one of those hoses starts to leak.
Steve
whitestroke
San Pedro, Ca.
« Reply #2 on: March 05, 2012, 12:04:00 PM »
Thanks, SCain.
Want to be sure before I put Airbox and Tank on.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
sugerbear
wentzville mo
« Reply #3 on: March 05, 2012, 01:11:35 PM »
don't buy the cheap caps at auto zone etc. they don't last very long.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: March 05, 2012, 02:30:35 PM »
Buy the caps for the carbs at red eye technical services...Here is their site...redeye.ecrater.com
« Reply #5 on: March 06, 2012, 07:20:05 AM »
Make your own with a short piece of vacuum hose and a stopper (such as a ball bearing).
Doesn't need to be a grandiose thing!
