November 24, 2025, 04:31:49 AM *
Author Topic: Metal to metal noise.  (Read 1322 times)
Steppenwolf
« on: March 16, 2012, 12:24:03 PM »
  I have a noise that sounds like metal on metal worn disc brakes coming from what sounds like the right side in/around the dryshaft. Only on downshifts, only hear it somewhere below 30 mph, and it goes away as soon as you pull in the clutch. Any ideas?
BonS
Blue Springs, MO
« Reply #1 on: March 16, 2012, 12:31:10 PM »
Have you been reading this thread? http://www.valkyrieforum.com/bbs/index.php/topic,39552.0.html
« Last Edit: March 16, 2012, 12:57:20 PM by BonS » Logged
john
tyler texas
« Reply #2 on: March 16, 2012, 12:31:36 PM »
pull the drive line/shaft ...
see what you have ...                Shocked
vrcc # 19002
F6MoRider
Lakeland, FL
« Reply #3 on: March 16, 2012, 01:51:25 PM »
How many miles on it?
Have you checked the u-joint?  Could be a bunch of things but I'd start by searching the tech boards for u-joint and start reading.
When my u-joint went, it made similar noise adjustments when changing gears and speeds.
Let us know what you find...
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
Steppenwolf
« Reply #4 on: April 29, 2012, 05:32:33 AM »
O.K., so found out that the noise I've been hearing is a dry spline. Honda recommends moly lube every 8,000 miles. Ironic that I have to chg, tire every 10,000. So, long story short, it's lubed, spline had no damge, no noise now, we're good to go mates!
Valkpilot
What does the data say?
Corinth, Texas
« Reply #5 on: April 29, 2012, 08:03:47 AM »
The pinion cup and drive shaft mating spines are often missed during final drive service.  If you didn't check, clean, and re-lube the pinion, I recommend it.  Moly grease (not paste) is called for, but any high-grade waterproof grease will do.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
