January 28, 2026, 04:57:30 PM
Shocks- need advice
Topic: Shocks- need advice (Read 2735 times)
Sourdough
Tucson
Shocks- need advice
May 17, 2009, 04:04:46 PM »
Went out for a ride today, smelled burning rubber, and found the right side of my tire
had been rubbing on something. Got back to the garage and found the bottom mounting
eye/bolt from the right shock broken off. Well I guess we need new shocks now, old ones
are Showa, OEM I assume. This is my first Valk so I thought I would ask for your help
as to what to replace them with. 97 Standard w 20K on the clock.
01 I/S Black/Beige
97 Standard Bumblebee
SANDMAN5
Mileage 65875
East TN
Re: Shocks- need advice
May 17, 2009, 04:28:18 PM »
I just replaced my Std. shocks with those from an Interstate. MAJOR improvement!
If I couldn't find a set of I/S shocks I was going with Progressive 440's.
May 17, 2009, 04:29:12 PM »
I like my 440 by Progressive with the chrome end caps and HD springs the length for the them is 12.5. Look good ride good and can make a passengers ride much more pleasant. Dont ask how I know lets just say when the wifes not happy no ones happy.
Thunderbolt
Worthington Springs FL.
So the bolt broke, not the shock?
May 17, 2009, 04:45:36 PM »
interesting, makes you wonder if it was loose from some prior work. That bolt has a large shank and small threads. Most folks that change, go with the progressive shocks.
DeathWishBikerDude
May 17, 2009, 04:57:08 PM »
I have a few extra sets of oem shocks off the bay.
About $50 per pair.
if I was buying new shocks,works performance would be my choice.
Compare the quality to the generic parts that progressive uses.
Like comparing a corvette to a pinto.
Progressive suspension can eat #$%^&.
Flameout 86
May 17, 2009, 06:05:56 PM »
I replaced the OEM shocks on my '97 tourer with Progressives at about 100,000 miles. They were the grade lower than the 440's. The ride was much better. Then I traded my '97 with 134,000 miles for a 2000 with 6,000 miles and found the ride to be much better. My plan, when I feel the need to replace the shocks that are now on my 2000, is to find some slightly used OEM's.
Tom
RUDE DOG - Steelers
New Jersey - VRCC # 3966
Reply #6 on:
May 17, 2009, 06:30:42 PM »
I just put the new Progressive 430's on my Valk. Check them out, very different and I love them.
