November 24, 2025, 01:44:44 AM *
Author Topic: side stand  (Read 1083 times)
N0tac0p
« on: March 23, 2012, 06:09:44 AM »
I have an 01 I/S. we all kjnow they lean pretty far, but my question is has anyone had problems with wear or a failure?.  Should i take it apart an look at it?  what should i expect to see?  periodically lube it with.....?
Currently, my side stand probably wiggles back and forth ~ 1 inch....normal?
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #1 on: March 23, 2012, 07:42:21 AM »
should be no wiggle room on a side stand, if it is wobbling that much I would think the safty switch may fail and or least the bike fall over...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
tank_post142
south florida
« Reply #2 on: March 23, 2012, 10:41:01 AM »
check the pivot bolt and then check underneath to insure the mount for the kickstand is secure to the frame
I got a rock Sad
VRCCDS0246
« Reply #3 on: March 23, 2012, 10:49:13 AM »
There is going to be some "wiggle", it's necessary for the kickstand to work properly.
Keep it well lubricated and it will work, always without a problem.
When it starts to get stiff you should recognize that it is not working correctly.
PINSTRIPERART
I ride a 2000 valk tourer
san antonio
« Reply #4 on: March 23, 2012, 06:20:39 PM »
the OEM bolt is way too weak, relace it with a grade a bolt. I have had this problem
