November 24, 2025, 01:44:39 AM *
Author Topic: Water in drool tube  (Read 1367 times)
amazngrace
Eastern Shore, Virginia
« on: March 23, 2012, 09:30:07 PM »
When I drained the drool tube,  clear water came out. I was expecting
oily dirty drool. What do you think I should be looking for?
Was getting ready to pull the tank and pods, check the vac lines and do
a general clean up and inspection anyway.
..ED
99 Red and Black IS
« Reply #1 on: March 24, 2012, 09:06:01 AM »
I'd guess it's from humidity. Cycles of heating and cooling draw water in and it condenses. If you're going into the air box, check it out but I wouldn't worry about it. Out here in DRY Arizona, I've only drained my drool tube once since 2003 and it was empty then. No humidity.
« Reply #2 on: March 24, 2012, 09:10:08 AM »
Mine is always an oil/crud and water mix, and I do it 5-6 times a year, and I always get stuff out.
bobm
Over The Pond
« Reply #3 on: March 24, 2012, 09:54:41 AM »
i have heard that tube is connected to the air filter and can get water in it when you wash your bike dunno how true that is
« Reply #4 on: March 24, 2012, 10:17:09 AM »
Most of the times MGM has been an oily filmed water.    Other times it has been just plain ole water.
I wouldn't worry about it.    Just drain it when needed.   That is what it was planted there for, a drainage pipe.
« Reply #5 on: March 24, 2012, 02:36:49 PM »
Mines the same as RJ's. I have a K&N so I guess its that oilly stuff.
« Reply #6 on: March 24, 2012, 06:45:19 PM »
drain it a few times a year and don't worry about it.  I've had a gunky slime crud come out and other times like last fall when colder out I drained it after riding at night in the fog and dampness out after work around midnight a lot and about 6-8 ounces of liquid came rushing out.  It kept coming out and out and thought it would never end.
amazngrace
« Reply #7 on: March 24, 2012, 08:21:52 PM »
I suspect it's water from washing. I haven't put 500 miles on it yet. Met the
PO to pick it up at an independent MC shop where he had taken it to be detailed and have the fluids changed.
Appreciate the input!
..ED
99 Red and Black IS
