November 24, 2025, 01:44:47 AM *
Author Topic: help with spline and final drive  (Read 2042 times)
fubar606
eastern washington
« on: March 24, 2012, 01:12:35 PM »
i am in the middle of doing this right now and need some help can anyone message me i will give you a number to call help
life is sexually transmitted and always fatal
fubar606
eastern washington
« Reply #1 on: March 24, 2012, 01:44:41 PM »
is the end of the drive shaft that gos into the hub with the grease seal .is it lubed with the drive hub oil or do i pack it with grease
« Last Edit: March 24, 2012, 03:18:47 PM by fubar606 » Logged
wild6
(Old enough to know better)
Vernon, NJ
« Reply #2 on: March 24, 2012, 03:50:24 PM »
Honda says to just coat with grease because the drive oil is supposed to circulate.
After you clean out all the crud, make sure the 2 holes at the bottom of the pinion cup are clear.  (use a wire or blow air in briefly) One hole delivers the oil and the other drains it back to the final drive.  If you tilt the drive cup-down, oil should start to come through the holes.
I coat the splines with grease (moly) and then also drizzle some drive oil in the cup and on the shaft to cup seal.  It's important that this seals to promote circulation.
Shaft before cleaning (note the oil coating):
Pinion Cup during cleaning (keep those holes clear):
« Last Edit: March 24, 2012, 03:59:21 PM by wild6 » Logged
« Reply #3 on: March 24, 2012, 04:34:43 PM »
Oh, now you've done it. You had to go and ask "that" question. Now you're in trouble.
Do you not have a manual, it tells how much lubrication to place onto that part.
http://valkyrienorway.com/download.html
I agree with the above post by wild6, but I haven't taken it apart and looked at it to compare.
« Last Edit: March 24, 2012, 04:37:19 PM by gordonv » Logged
dukesguy
« Reply #4 on: March 25, 2012, 12:34:46 PM »
How do I seperate the drive shaft from the pinion cup? I had mine apart last week, but couldn't pull them apart. I didn't want to force anything. New Avons going on this week and would like to check this part out. Drive splines look good. Thanks.
Daniel Meyer
The State of confusion.
« Reply #5 on: March 25, 2012, 12:47:54 PM »
I put a towel down so I don't scratch/damage the pumpkin, then hold it up an inch or so above the towel by the driveshaft, then tap the pinion cup with a hammer or something. Just pops out.
CUAgain,
Daniel Meyer
Quicksilver
Norway Bay, Quebec, Canada
« Reply #6 on: March 25, 2012, 01:51:06 PM »
Pulling on it, moving it side to side to compress the clip on the end will get it out. No large hammers or tools needed.
1997  Standard
