November 24, 2025, 01:44:43 AM *
Author Topic: Creaking rear shocks  (Read 927 times)
delucaj
« on: March 25, 2012, 05:46:23 PM »
My 2001 Interstate only has 8000 miles on her but the rear shocks creak like a rusty gate.  Sounds like the springs are rubbing on the inside of the spring cover.  What about the mount bushings.?  Anybody have any experience with this?
Sodbuster
« Reply #1 on: March 25, 2012, 05:54:55 PM »
Mine has 41k and does the same thing .... curious to know what others have to say
VRCC # 30938
GotValk
Champlin, MN
« Reply #2 on: March 25, 2012, 06:13:27 PM »
Check and make sure your shock isn't rubbing on your fender. I notice  when I had mine down for tires that the left side shock had been rubbing on the fender, I never heard it creak but I always have the music on so that doesn't surprise me.
Anyhow mine doesn't rub now.
« Last Edit: March 26, 2012, 01:35:30 PM by GotValk » Logged
Chattanooga Mark
« Reply #3 on: March 25, 2012, 06:42:18 PM »
Are the upper bushings worn out? I just replaced them with Gary's poly bushings on my 99 Interstate with only 15,000 miles. The upper bushings were shot and I had a front end wobble. With the new bushings, even the wobble is gone. As far as I know, my rear shocks never did creak.
All the best,
Mark
www.bikersforchrist.org
Michvalk
Remus, Mi
« Reply #4 on: March 25, 2012, 06:43:24 PM »
Just a guess, but, I would think the bushings are dried out. Not enough miles on them for the shock to have an internal problem. Could just replace the bushings and see if that fixes the noise. That would be a cheap thing to try first. Next question will be what kind of bushings. If you ask you will get 5000 answers. Almost any kind would be a good try to find out if that is the problem. Or you could just squirt some lube on the pivot points to see if that stops the noise. cooldude
