March 30, 2026, 10:12:42 AM *
Author Topic: rounded off bolt  (Read 1267 times)
F6BANGER
Albuquerque NM
« on: March 27, 2012, 03:11:42 PM »
I posted this on the Tech board but know more people look at this board.
The 10mm bolt that goes into the tranny cover is rounded. The cover in question is the clutch side cover. (Its the one on the right in the pic). Any one ever have a problem removing this. How did you do it. Thanks
Raverez
No good deed goes unpunished
Central New York State
« Reply #1 on: March 27, 2012, 05:23:11 PM »
vise grip pliers might help. If not you might have to drill it out and replace with a new one
« Reply #2 on: March 27, 2012, 05:26:15 PM »
Get a set of these at Sears, you may only use it once in a great while but it's a life saver. My wife got it for me as a b'day present a few years ago, best tool in the cabinet on the day you need it.  cooldude
http://www.sears.com/shc/s/p_10153_12605_00952166000P?prdNo=4&blockNo=4&blockType=G4
wiggydotcom
Yorkville, Illinois
« Reply #3 on: March 27, 2012, 06:03:05 PM »
+1 to what John said. It saved me getting the rear caliper bolt out that the PO had rounded off. If I never use em again, it was worth it to buy the set.
VRCC #10177
VRCCDS #239
« Reply #4 on: March 27, 2012, 06:03:55 PM »
+ 1  I have a similar one from Harbor Freight and it has saved me a lot of time and trouble.
F6BANGER
Albuquerque NM
« Reply #5 on: March 28, 2012, 06:40:31 AM »
Thanks for your responses. The ones from sears look like the clearance isnt there. Harbor Freight doesnt have any in stock. I hafta call them back Friday when the truck comes in.
Westernbiker
Phoenix
« Reply #6 on: March 28, 2012, 08:21:05 AM »
First off, LOTS of WD-40 and let it soak in over night. Next morning smack the bolt head with a hammer then try the vise grips again. Works for me every time.
flcjr
Manhattan,Montana
« Reply #7 on: March 28, 2012, 09:19:29 AM »
They are not as cheap as the ones from sears but will allow more clearance as they are a socket and you can use a ratchet and extension. MAC tools sells them in socket form. Check your local dealer your local mechanic should have his number. They are a life saver. you can buy just the one you need and not the whole set if you want. I don't work for MAC just like a few of there tools and this is one of them.
F6CTrider
Denver, Colorado
« Reply #8 on: March 28, 2012, 09:57:32 PM »
As for a penetrating solvent / loosener I much prefer PB Blaster to WD 40.  It works like Voodoo.
If clearance will not allow the tools from above...... slot the bolt with a dremel and get a B--F---ing screw driver.
Naturally you will want a new bolt regardless of what you use.
I have made a habit of applying a dab of assembly lube on things to fight corrosion and other issues with frozen bolts, screws, and nuts.  I have having frozen nuts! 2funny
F6BANGER
Albuquerque NM
« Reply #9 on: March 30, 2012, 02:03:10 PM »
Well I called HF this morning to see if the truck came in. I went on their website so I could just give them the item number. Well, their website was down this morning. So I called. She said the computer showed 3. I asked her to physically check and she put me on hold. 10 minutes later I said "F" this and hung up. I went over there and they didnt have any in stock. The manager looked in the back and came out about 15 minutes later. He told me to try these. I have never seen or heard of them and it worked great. The Manager gave me 50% off since I waited so long cooldude Thats how business should be done. cooldude cooldude
http://www.harborfreight.com/7-piece-3-8-eighth-inch-metric-spline-socket-set-96362.html
