November 24, 2025, 12:29:33 AM *
Author Topic: Enlighten me. Light bulb ?  (Read 1075 times)
YoungPUP
Valparaiso, In
« on: March 29, 2012, 05:47:04 PM »
Converted my rear turnsignals to 1157 to use as stop/tail/turn due to the shaved taillight on my fender. Using Red LED bulbs they flash fast with the stock flasher, and with the electronic flasher the hoppy converter isn't happy. The instructions say its limited to 2 amps per side.  Does an 1157 bulb fall in under 2 amps??  I tired to figure it out but with all the adding and multiplying all I end up with is an answer of : Chair???  TIA
99 STD (Under construction)
« Reply #1 on: March 29, 2012, 06:17:37 PM »
I have the same conversion and have no problems. I use clear bulbs with red lenses. Stock flasher. Might you have reversed the filament wiring in the socket??
YoungPUP
Valparaiso, In
« Reply #2 on: March 29, 2012, 06:23:27 PM »
Doubt its mis wired, works fine with the stock flasher, but very dim with the electronic one. Will switch to 1157 and paint the clear lenses. Thanks
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: March 29, 2012, 06:32:51 PM »
Try either a variable load electronic flasher or a heavy duty regular one.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #4 on: March 29, 2012, 06:33:17 PM »
You can buy the red lens if your interested.  Cool
http://www.phatperformanceparts.com/Clear_Alternatives_Clear_Colored_Turn_Signal_Len_p/cts-0020.htm
My rides:
Valkpilot
Corinth, Texas
« Reply #5 on: March 29, 2012, 06:40:30 PM »
amps = watts / volts
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
