March 30, 2026, 10:07:35 AM *
Author Topic: Need Good Valkyrie Mechanic  (Read 1094 times)
f6rider
« on: March 31, 2012, 07:33:46 AM »
God Morning. I just purchased another Valkyrie that has not be started in 7 years. It starts and runs like *&*(&.
Anyone know of a good Valkyrie Mechanic in northwest ohio or southeast michigan area? I am sure the carbs need to be re done.
May within a 2 3 hour drive from Toledo Ohio.
Thanks for your help.
John Wodarski
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: March 31, 2012, 07:40:04 AM »
John,
If the bike starts and runs, how about putting fresh gas into the tank and put about a third of a bottle of "Techron" to clean out the carbs?
That could be your fitrst course of action before paying someone to work on it.
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: March 31, 2012, 07:50:13 AM »
+1 on what Momz says, Fresh gas, techron, and a long slow ride with several stops to soak for 30-45 mins.  Then more fresh gas and techron, leave it sit overnight.  Momz is closer to you, but if you still need help, we're a phone call away.
« Reply #3 on: March 31, 2012, 08:55:13 AM »
I'd put the entire bottle in there with a tank of fresh gas.  If it'll ride, take it for a ride and keep it under 2000 rpm's for most of that tank.
henry 008
BRP
willard, oh
« Reply #4 on: March 31, 2012, 09:31:03 AM »
i use accurate cycle in lagrange. closer to clevland than toledo tho.  call kevin at 3302251107.  ernie schuster from valkyrie dragon exhaust swears by him, and ernie is a 1st rate mechanic in his own right.
Safe Winds... Brother
