January 28, 2026, 06:26:44 PM *
Author Topic: Final Drive Oil Change  (Read 2828 times)
Boomer
Oklahoma City
« on: May 20, 2009, 11:38:54 AM »
I am prepping for a trip and as part of the maintenance, read that changing the Final Drive Oil is recommended, but could not find out how often.   Any suggestions on how often or issues that may arise.
Bagger John - #3785
« Reply #1 on: May 20, 2009, 12:23:09 PM »
I do mine at every tire change, or whenever I have the right-side exhaust off. Use a good synthetic gear lube and the stuff will last longer between changes. Spec'd interval is (IIRC) either 16,000 or 24,000 miles.
« Reply #2 on: May 20, 2009, 12:42:55 PM »
An easy to find synthetic is Pennzoil. Wal Mart sells it as a Marine lower drive unit gear oil. 75Wx90 with the required GL5 rating for our drive units. About $7 and has 6 changes in it. I do mine annualy.
Daniel Meyer
The State of confusion.
« Reply #3 on: May 20, 2009, 03:34:29 PM »
I do mine every 10,000 miles, which is every air filter change and every other oil change.
CUAgain,
Daniel Meyer
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #4 on: May 20, 2009, 07:41:04 PM »
I believe the "good book" says every 16,000 miles...simple procedure...I use a plastic tube to get the oil in.  I also replace the seals.  FYI, the final drive drain plug seal is the same as the engine oil drain plug seal! Wink
Never hurts to do maintenance early! cooldude
« Last Edit: May 20, 2009, 07:49:40 PM by Valk Boy Jr. » Logged
DeathWishBikerDude
« Reply #5 on: May 20, 2009, 08:48:21 PM »
Make sure to replace the o ring on the plug,and don't try to over torque it.
You will break it right off.
The plug is cast,not solid aluminum.
 uglystupid2
Boomer
Oklahoma City
« Reply #6 on: May 25, 2009, 08:42:56 PM »
Thanks everyone, this is the perfect kind of info I needed.
Warlock
Magnolia, Ms
« Reply #7 on: May 26, 2009, 04:45:10 AM »
I do my rear end every 10,000 miles. That is when I pull my rear end for service and the splines, and pinion joint.
David
